Question about Dometic Rooftop RV Air Conditioner
I just had a new Dometic roof air conditioner installed it works good for about 10 min. the the fan stops and makes a humming noise .After about 10 min the air will work ok again. The repair tech saya the fan moter is drawing about four time the amps lt should. He is going chang the fan capacitor or fan motor. Is this a problem with Dometic AC units?
    Scholar:
  • 133 Answers
I have over 35 years in the A/C business and am ASC certified. The motor will normally draw 4 to 6 times it FLA (Full Load Amps) or RLA (Regular Load Amps) when first starting up or is seized. This is called LRA (Locked Rotor Amps). These specs can be found on the motors nameplate and can be checked with an amp meter. If the motor hums and won't start while pulling these high amps, Try giving it a spin with a stick. (in the right direction of course). If it keeps running when helped to start, its probably the capacitor. They normally run about $7.50 wholesale. If its tight in both directions while humming, 1 or more of the field poles is out of balance and the motor will need replacement. Good luck and be careful when spinning it.
Posted on Mar 31, 2011
Testimonial: "Thanks the RV shop wo installed it are going to contact Dometic and He thought the same as you. Thanks!"
Dometic caravan rooftop airconditioner fan is making a loud ticking noise
remove the cover off a/c on roof. should be able to see if fan blade or squirrel cage are hitting anywhere while running.
Jan 04, 2014 | Dometic Heating & Cooling
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
Hi' I have a coleman roof top AC unit on a 1991 Tioga i just purchused a couple of months ago! When i turn on the AC it makes a humming sound...no fans spin or no air comes out! If i let it hum for...
The blower motor is seized up...you will need to get up top and remove the cover...then remove the fan blades and the motor and replace the motor....sometimes a temp. fix will be to get WD-40 and then oil worked into the bearings...but that is usually a very short lived fix...
Replacing the motor can be frustrating and time consuming, so you may want to hire someone to do it for you...you may also find that a replacement unit is more cost effective..
heatman101
Jun 14, 2011 | Dometic Rooftop RV Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
Fan does not run. Low power hum audible.
sounds like you have a bad run capicitor on your fan check if the cap is swolen and or any oil around the terminals thats usualy a tail tell sind thats its bad
Apr 08, 2010 | Dometic Rooftop RV Air Conditioner
I have a dometic roof mounted air conditioner 3300 series and it developes this vibration like a real loud hum
sounds as if the fan motor bearing have worn out lettin the fan cage wobble upon reaching full speed hence the vibration. There also could be build up of debris in the fan assembly. Good luck on your repairs
Dave
Oct 16, 2009 | Dometic Rooftop RV Air Conditioner
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
386 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
