Question about General Electric WBVH5300KW Washer
It seems that my washing machine always ends on a very hot cycle regardless of the setting I have it on.
  • 3 Answers
Have you checked that your hot and cold lines are not crossed?
Posted on Mar 31, 2011
Cold water setting not working-only hot comes out
The cold cycle begins with hot water to dissolve powder detergent regardless of whether you are using powder or liquid.
Jul 27, 2016 | Whirlpool Washing Machines
Will not advance automatically through cycles. Ha...
I would have thought it was the board too! does it beep when it stops? if it does then it should be putting up a fault code.top row of lights..CHeck that you have both the hot & cold hoses connected & turned on at the taps.even if you are not useing hot water to wash with,turn them both on anyway.Some machines require this regardless of wether you are useing hot.The reason for this is F&P have built into their machines to give a little squirt of hot water to maintain a certain level of cold wash.Make sure also that hot hose is going to hot valve & cold to cold.
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 300 washing machine warm water cycle is hot water
You have to check the thermostat connected to heater circuit.
Apr 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Nov 19, 2009 | Washing Machines
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
I have a Neptune 2000 stackable washer. It seems that water is always remaining in the drum after a cycle, and water is sitting in the rubber gasket at the door. I am getting mold on the gasket and odor...
All washers still have some water in them at the end of the cycle. If you wipe the door boot down with a mild bleach and water solution this will keep it from getting mold. If you don't do a bleach load on a regular basis I would run a hot wash with 1/2 cup bleach and 1/2 cup powder cascade with no clothes once a month to keep the machine cleaned out. I also always leave my door unlatched when not in use.
Apr 23, 2008 | Washing Machines
LG Tromm Washer
Embarrassing as it was, the hot/cold water hoses were switched - although it was installed by HomeDepot that way. It just didn't seem consistent enough for it to be such an easy solution...but it did the trick!
Dec 20, 2007 | LG WM2688HWM TROMM SteamWasher
General Electric WBVH5300KW Washer Logo
43 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
