Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
I have a Lifan lf50st-A quad . It was running great then it stopped and now it has no spark ?? paul.
Have 200 Chinese quad the starter motor is spinning but the engine isn't turning over. Any advice would be appreciated.
The selenoid moves the gear to latch the pinion when electrict get the starter
X
Check selenoid is latching
Feb 15, 2015 | ATVs
My lifan 125cc is spluttering threw the gears n isnt accelerating properly
Lifan... That's chinese right?
Any problems with performance can be reduced to spark problem, fuel problem, or compression problem. Check spark first as that is easiest. Make sure to check ignition coils and such too. Then check the carb. That can get gummed and gunked easily. Not to mention the settings need to be just right.
Nov 09, 2014 | Motorcycles
Cutting out
Hi Thomas only thing I can think of is that its not getting enough air is it the right filter as it may be not be allowing enough air through. As you probably know if you don't get the right amount of fuel & air it won't run right. Hope it helps cheers Paul
Jan 23, 2014 | ATVs
Grizzly 350 wont fire
First check the fuses.check the start ,run switch,there should b some kind of protection for this..possibley a in line fuse??
Aug 07, 2012 | Yamaha Grizzly 350 4x4 07 Airbox Air Box
Lifan 50cc scooter not starting. I replaced choke solenoid and cleaned the carb. Am getting spark and putting sight vacuum on on hose leading to gas tank valve does produce gas flow in hose attached to...
It requires three main things to start the scooter:--- 1)Gas. 2) Spark. 3) Cylinder compression.---------- Any of the one is not functioning right so scooter is not starting.------------ Its possible that gas is not flowing till the carb and that is causing the problem.Either gas valve is clogged or faulty.Or gas line is clogged or carb itself is dirty and gunked up inside and needs to be cleaned.--------- Click this link below and follow the troubleshooting :--- http://whatisbyme.blogspot.com/2011/08/lifan-50cc-scooter-not-starting.html ----------- This will help.Thanks.Helpmech.
Aug 18, 2011 | Lifan Knight 125 Motorcycles
I clean spark plug on my 2005 honda it runs for
check to see if you have any seals or gaskets that need replacing, could be fowling plugs due to oil getting into the cylinder
Apr 07, 2010 | 2002 Honda CRF 450 R
Lifan metro scooter wont turn off
have a look at the cdi plug ...one of the terminal in the plug cluster may have a broken wire or not making good connection with the cdi.
Jan 13, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Quad bike wont start, just turns over
To check the spark put the spark plug in the cap and rest the tip of the spark plug on the head of the engine and crank it over. You should see a strong spark.
(Remember doing this creates electricity so don't touch the tip)
May 27, 2009 | RTO Mini Quads
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
234 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
