Question about Epiphone Limited Edition Wilshire Pro Electric Guitar Ebony
I thought I had a bad guitar cable. Then, I thought the 1/4' output jack was loose. Now I think the 3 way switch is bad. I have a very scratchy annoying sound that happens in all the 3 way positions. I have split coil pots. Also, the neck pickup can't be heard in the middle position.
    Novelist:
  • 184 Answers
It seems that your 3-way switch is suffering from bad contact. Well, there are three things you can do:
1 - Take the guitar to a service representative and have it repaired,
2 - If you are proficient in the use of a soldering iron, you could desolder it from your guitar and replace it for a brand new one (do not forget to take notes of the cable colors and where they are soldered before removing it), and
3 - Try using a contact cleaner spray to clean its contacts.
The contact cleaner spray is a spray can filled with special formulated chemicals and/or gases that helps cleaning the switch and pot contacts. It generally comes with a thin tube that allows you to insert its tip inside the switches or potentiometers and spray its contents exactly where it is needed. While spraying, move the switch rocker or potentiometer cursor from one side to the other, allowing the fluid to clean the contacts, removing any debris that might be located there and originating the bad contacts that may be causing the scratchy noise you hear..
These contact cleaner sprays can be found in most hardware stores, electronics dealers, and hobby shops or even in the Internet, from different brands (3M, Polywater, MGC chemicals, CRC, etc ).
Hope this may help you put your Epiphone to scream loud and clear again...
Posted on Mar 31, 2011
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
Hi, I have an RBX 374 and I cannot get any sound from it. I have got the wiring scheme but the wiring looks O.K. Some say it might be the pre-amp. Does anyone know what could be the problem...
i dont' see where this model has active pickups (guessing this is what you mean by pre-ampped).
The issue can be in a few places.
1) the strings could be too far from the pickups and the instrument needs to be tuned.
2) the pickups are bad
3) your jack is bad
4) the cable is bad
5) your equilizers are not corrected
6) your volume control is turned down or damaged
7) your amp is damaged
this is a small list of the basic possibilities.
Mar 29, 2011 | Yamaha Rbx374 4String Electric Bass Guitar
I have a Frontman Fender 25R, it has a power, the auxilliary input is working (the RCA, red and white ) sound is produce, when I plugged an electric guitar on the 1/4 input there is no sound coming...
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Mar 25, 2011 | Fender FrontmanTrade 25r Combo Guitar...
Hi! My TP-4T preamp on my Takamine EG124C works only when tuner is ON. After tuner automaticallt turnes off, the sound stops. Please help!
Hello,I am a guitar tech in Nanaimo,BC,Canada and have run into this problem before.Simply replace the Takamine output jack [where the guitar cord goes into] 3 screws and solder,and it will work fine again.The jack has a switching mechanism in it and when it fails it shorts the output out.The jack is available at most Takamine dealers or Allparts http://www.allparts.com/SearchResults.asp?searching=Y&sort=7&search=jack&show=20&page=5
Mar 06, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
I get a lot of scratchy electric interferance noise when I play my guitar, but it hasn't always been this way...just started
Unless something has suddenly happened to your guitar (like being dropped) start by eliminating as many external factors as possible.
  1. If you are using an effects pedal plug straight into your amp to see if that cures it.
  2. Turn off any other electrical equipment in the vicinity that could be causing interference.
  3. Try changing your guitar lead - it may be just poor screening or cracked insulation in the cable.
  4. Try switching back and forth between the different pick-ups and also fully rotate all the volume and tone control knobs quickly several times - the contacts may have got dirty over time.
  5. Pull the jack plug in and out several times to make sure it isn't dirty contacts in there too - if it is give it a little squirt of 'switch cleaner' spray - available from most electronics suppliers or online via Amazon E-Bay etc.
  6. Check the screw bezel (threaded ring-nut) that holds the jack socket in the body of the guitar. Sometimes these work loose over time and then the jack plug doesn't quite go in far enough resulting in poor electrical contacts.
  7. If your guitar has active circuitry pick-ups also replace the battery - use high quality batteries (Duracell Ultra or similar) never re-chargeables as they don't hold high enough voltages.
  8. Try a different guitar to see if the problem is in the amp. Stand or sit in a different position, move about, turn round 90 degrees to see if it is just interference between the guitars pick-ups and the power supply in your amp.
  9. If none of the above works then it is likely to be a problem with the guitar's electrics - don't tamper if it is still in warranty. Carefully remove the back plate to see if any wires have come loose - it might be a dry solder joint on the jack socket or one of the control knobs so may not be immediately obvious. If the screen wire (sleeve of the jack plug) has come off it may not stop the guitar working but it may cause the noise problem.
  10. Beyond that I can only suggest taking it to a qualified guitar technician who can fully check the electrics with a test meter.
Jan 30, 2011 | Hagstrom Viking Semi Hollowbody Electric...
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
Black cables loose
Does the jack have any wires connected to it? Can you tell where the disconnected wires originate? Typically, the wire from the middle ear of the volume pot should go to the tip of the jack, and the wire from the back of the tone pot goes to the sleeve of the output jack. You will get no output if either of these wires are disconnected. Also, the next question is "why" did they come loose? That's usually because one of the pots is not tightened down, and is allowed to spin when the volume or tone knob is turned, breaking the wire's contact. Pull the knob off the pot, and tighten the nut down so the pot can't turn. This will assure you won't have the same problem again.
May 26, 2010 | Dean Vendetta XM Electric Guitar
MAIN MIX O/P FADER
The fader is likely a dual pot. The manufacturer is likely ALPS. You need to match the board hole layout, slider throw, resistance, AND TAPER.
There will be a number on the side of the pot that will have the resistance and taper... It is likely an "A" taper which is an audio log taper.
Replacing this involves removing about the right 1/3 of knobs, screws, and jack mounting nuts and washers to remover the circuit board the pot is mounted on.
There are connecting cables to be removed.
Try to find part at DigiKey.com or Mouser.com. Note that the handle MAY be too long. Shorten the handle with tin snios and remove the burr.
BEFORE any of this is done, you should investigate to make sure it is the fader. If the left channel is intermitent scratchy then the fader is likely bad, These will get scratchy before they fail... If that is not the scenario, then there probably is something else bad.
Since the board is similar to the eurodesk model, on that one DO NOT plug mono 1/4 inch plugs into the mains output 1/4inch jacks as those are TRUE TRS balanced lines.
May 09, 2010 | Behringer XENYX 2442FX Mixer
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Epiphone Limited Edition Wilshire Pro Electric Guitar Ebony Logo
113 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
