Question about Mitsubishi VS-60607 TV
Mitsubishi VS-60607 tv
Hi Tonyomaha,
I have the same tv and same problem that you have. Did you ever have your problem fixed. Please advise me if you have the solution.
thanks
  • Mitsubishi Master
  • 13,434 Answers
Can you tell us about the problem you are faceing?
Posted on Aug 05, 2008
SOURCE:
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
Screen role red and green wavie lines.
Hello dctc1,
Looks like there is a problem with the convergence IC's. You will have to replace both of them. I would also look for busted capacitors around the IC's.
However, if you are not familiar with TV repairs, I would advise against opening up the set. Best get a service man to come and diagnose/repair the set.
Hope that helps!
Please dont forget to rate or "Accept" the solution if it helped you in any way, or leas you to a fix.
Thank you for using FixYa!
IrishDruid
May 18, 2008 | Mitsubishi VS-60607 TV
I must dispose of my Mitsubishi VS-60607 Projection TV. I have a weight requirement for disposal. My manual failes to specify the weight of my TV. What is the weight of my TV?
This thing weight 200 pounds.U can't dispose tv in ur regular disposal.This must gose to Electronic recycle center.Becauce,it have leads and chemicals inside it component parts.
Sep 09, 2010 | Mitsubishi VS-60607 TV
How can i get a schematic for the mitsubishi vs-60607 convergence circuit
U don't,the corporation does not allow it.U can get the convergence kit,comon prob.for all DLP tv.U know how to solders right?try this website for the convergence kit,use what in that kit,should solve ur convergence prob.
Oct 20, 2009 | Mitsubishi VS-60607 TV
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Skyassoc
Jul 04, 2009 | Mitsubishi VS-60607 TV
Does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
Dec 12, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Jun 12, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
