Question about Samsung SyncMaster 204t 20.1" Flat Panel LCD Monitor
Monitor doesn't turn on. there is a green light by the power button that simply blinks continuously when powered on.
  • 11,361 Answers
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 31, 2011
Testimonial: "awesome! is there somewhere I can send it though, I really dont' want to **** it up, it's an awesome monitor. "
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
When I turn on my Canon iP3000 printer the power light blinks five orange and one green light and continues to to so. It will not stay solid green.
Hello try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Samsung SyncMaster 204t 20.1" Flat Panel LCD Monitor Logo
104 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
