Question about Makita MAC5200 Electric Powered Air Compressors
I have a makita MAC2400 2.5 HP that suddenly stoped It's almost brand new but does get plenty use, the oil level was very low or may have just ran out. I added more oil but will not come on, what is the problem and can it be fixed does the motor have a reset button?
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Remove the rear cover Item 33 this link:
http://www.ereplacementparts.com/makita-mac2400-25hp-1720rpm-air-compressor-parts-c-97_1547_7559.html
Gently start rocking the fan GENTLY back and forth by gripping it in the large center area and see if it will rotate. If you ran it completely out of oil; the piston, piston rings or rod end bearings will seize up. If you can not rotate it by hand and your sure it has locked up... you are going to have to overhaul the pump or replace it. The link above is a good source for parts.
Before considering an overhaul... read out the motor windings after the pressure switch to see if the motor windings are open or read a resitance value under 480 Ohms.
Depending on the motor pump used most of them have thermal overloads that will self reset when the unit cools off. It should self reset in less than 15 minutes if there is one. Ones without a thermal overload end up cooking the motor windings or tripping the house circuit CB if they run out of oil.
Thanks for choosing FixYa,
Kelly
Posted on Mar 31, 2011
Low oil pressure light suddenly came on
If levels and sensor checked and working, very likely oil pick up pipe, the pump inlet is blocked.
Apr 03, 2014 | 2006 Chevrolet Impala
My Briggs 23hp ran out of fuel is there a reset switch as the engin will not start anymore.
I would be checking low oil level as there is a low level oil switch that switches off when you run low on engine oil.
May 10, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Engine starts and stops ticking
Sounds like oil pressure problems to me. Check to make sure your oil level is correct. If the oil level is OK get the engine checked by a professional.
Mar 24, 2012 | Chevrolet S 10 Cars & Trucks
I have a valsi 7500 watt 13 hp with tecumseh enduro xl/c engine-its extremely loud and wouldn't stay cranked. My ex - an ''idiot'' worked on it without my knowledge - we now have lines that we don't know...
Valsi 7500 watts/13hp tecumsa engine. Was running fine and then started surging like it was going to die and then it ran out of gas. Put fuel in it and now it wont start. Gets fire and has plenty of gas. Problem???
Jun 23, 2010 | Electrical Supplies
Snowblower was running for 1 hr. i shut it off when i restarted it ran 1 minute and stoped could not get it started, it it sat for 6 hrs. and started but would not run at higher rpms. it seemed to sputter
Hi. And welcome to FixYa. I am Kelly
From the symptoms you describe it sounds like the low oil sensor is shutting of the ignition.
i.e ran for 1 hour... hot oil... / low oil level ignition cut off. Sat for 6 hours all oil now in crankcase... started and higher rpm sputters....
Check the oil level. Other than that I think everything is fine.
If not please respond with a "make and model" of your snowblower. After that, there is more that we can do to resolve the problem.
Thanks for using FixYa!
Kelly
Feb 11, 2010 | Garden
Makita MAC 5200 3 HP 5.2 Gallon electric compressor
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Feb 22, 2009 | Makita MAC5200 Electric Powered Air...
Won't start
low oil switch stuck. most new small engine have a low oil swich in the oil pan. this can be by passed or replaced.
Dec 21, 2008 | Coleman Powermate Subaru 5000W Portable...
Makita Generator suddenly stops has gas
Hi
Hi See if the gas tank cap vent is clogged,remove the cap and check the gasket in it.Check the flyweel key(not to be sheared) and the condenser( not to be defective).The ignition points(not to be burned).Check the oil in the crankcase(pay attention to the low-oil-level shutoff sistem (if there is one).Check the fuel lines and filter.Check the muffler(not to be clogged).Check the plug wires and make sure is securely attached at the sparkplug.Check the cable and linkage.
best regards savumihai71
Dec 15, 2008 | Makita 9 Hp 4,300 Watt Portable Generator...
Makita MAC5200 Electric Powered Air Compressors Logo
547 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
