Question about Kenmore 94802 Front Load Stacked Washer / Dryer
Our washer makes a terrible, loud noise in the spin cycle. It is deafening. Is something going out on it?
    Brigadier General:
  • 6,277 Answers
(really try this first!)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 31, 2011
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Sounds like gear or something is stuck in washer
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. To watch a free video on how to check and replace this part go to www.appliancehelponline.com/servicemanual.html this will walk you thru this. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations.
Mar 30, 2010 | Estate TAWX700JQ Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
TERRIBLE NOISE ON SPIN CYCLE
That is normal, after a little while all washers make that horrible noise you should be able to put up with it
Hope this helps! - Josh
Feb 03, 2008 | Frigidaire GLWS1233A Top Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Kenmore 94802 Front Load Stacked Washer / Dryer Logo
61 people viewed this question
Sal De
fordexpert
Robert Rankin
