Question about HP OfficeJet G85 All-In-One InkJet Printer
Cant send fax dials squeals and cuts out and busy signal?
    Novelist:
  • 129 Answers
Hi There!
Please check if the phone line where the fax machine is connected is working. You may try to disconnect the fax machine from the walljack and connect known-working telephone on that jack and try to dial/call anyone. Because sometimes this issue can be caused by the problem on the phoneline.
Hope this helps. Please rate if it works. Thanks
Posted on Mar 31, 2011
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Sep 28, 2010 | Brother Office Equipment & Supplies
I cant fax
Take your cell-phone, and dial the same number, to see if you get the same "busy" signal.
If the telephones in your business require you to "dial-9" to get an "outside" line, be sure that your FAX is also following that "dial-9" protocol, and also waiting 1 or 2 seconds after the "dial-9", in order to get the dial-tone from the "outside" line.
Dec 10, 2009 | Brother MFC 240C All-In-One InkJet Printer
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
The machine seems to work ok, except when putting in a fax document, inputting the #, and pressing fax start, it pulls the document through, then just beeps every 2 seconds. It then does put out a...
The number that you are sending to is either busy, disconnected, or off the hook. To chek BEFORE dialing press the "HOOK" button (located to the left of the "1" key) and listen to the transmission this will help you in your troubleshooting. If you don't hear a dial tone BEFORE dialing, then the trouble is on your end.
A fast-paced busy signal could indicate a "downed" telephne line.
Finally, sometimes the line that you are sending to has so much stuff hooked up to it (56K dialup fax, multiple phones, alarm system dialer, credit card validator, teenage daughter) that you may be better off e-mailing instead.
GL
Jul 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Can not send out faxes
You have to get your phone line checked out .
Apr 28, 2009 | Brother IntelliFax-2820 Laser Fax
HP OfficeJet G85 All-In-One InkJet Printer Logo
124 people viewed this question
Seeker5211
Seeker5211
