Question about Fisher and Paykel Fisher & Paykel Washer
I'm renovating and need to move the taps to the smart drive washing machine. Do the taps need to be higher than the machine or can they be the same height. I will be juggling window and door positions too. Thanks
    Problem Solver:
  • 9 Answers
No, not the supply lines, the are selonoid controlled by the timer. however the drain line MUST be higher the clothes drum or the water will siphon drain out.
bb.
Posted on Mar 31, 2011
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
Smart drive washing machine
That will require a technician to fault find.
Jul 06, 2017 | Washing Machines
Please can you help. My F&P smart drive 703 does not complete the water fill process. It stops and starts, filling with water intermittently and then suddenly beeps continuously as though it has
Maybe you have the cold tap hose connected to the hot inlet valve. Check the hoses. Need more info on the beeping. Is it a steady beep or more of a musical rippling sound? Also, what lights are on especially along top row when it beeps but also describe any other lights that are blinking? The top row lights won't be blinking, so just count and tell what number lights are on and which are off ( count from left to right)
Aug 15, 2017 | Fisher and Paykel GWL11 Top Load Washer
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
F&p washing machine
Replace the dual inlet water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine
check the pressure switch it the switch which lets you choose the water lever proably needs replacing
Mar 19, 2008 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
