Question about Refrigerators
I have 2 water line connections which one is connected to the main source
  • 66 Answers
Do you have 2 lines out of the wall? Do you have an ro system? Need nore info to help with question.
Posted on Mar 31, 2011
Nshow me how to wire Eaton 100amp disconnect
A disconnect is simply as it's called (a disconnect) it is connected directly to the power source and all circuits following depend on the disconnect to provide the connection to the main source. Like a main water line to a home ,there is always a main water value from the city located at your property which must be open to allow water to your home. The electrical disconnect works the same way with electricity from the provider to your home .
Sep 29, 2014 | Electrical Supplies
Remote install
1) Copy following link:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#remote
2) The remote does not connect to power source, or it will burn up
Feb 06, 2013 | Rheem Tankless Hot Water Heater...
Which water line or lines do I connect to refrigerator, model # ED22RFXW01, man. 08/99
It's advisable to go with flexible plastic tube with sweet water supply. Please follow the instrction as per video attached.
Even if your refrigerator comes withan automatic icemaker, you will need to connect it to a water supply for it tomake ice. While this is not a particularly difficult job it requires someknowledge of plumbing and the use of tools. ThingsYou'll Need:
  • Compression Nuts
  • Knife Or Scissors
  • T-valves
  • 1/4-inch Copper Or Plastic Tubes
  • Drill Bits
  • Variable-speed Drills
  • Drill Bits
Read theinstruction manual that came with your refrigerator. Specific instructions forhooking up the icemaker may be included. Locate thepipe nearest the icemaker that carries cold water. Most often, this is the coldwater pipe that connects to the kitchen sink. Install at-valve in the main cold water line - not on the 3/8-inch faucet tubes - sothat there are two outlets: one to the sink and one to the icemaker supplyline. Turn offthe water. Put asleeve and compression nut over the line that will supply the icemaker in orderto tightly connect it to the water line. Turn thewater back on, and, holding the end of the tubing in the sink or over a bucket,flush the line to remove any debris. Turn the water off again. Snake theline from the water source to the icemaker connection, drilling holes in thebacks of cabinets if you have to in order to push the line through. Find theicemaker inlet from the refrigerator and attach the other end of the line usinganother compression nut. Turn thewater back on. Throw awaythe first few containers of ice to be sure the line is completely clean beforeyou use the ice.
http://www.youtube.com/watch?v=vB-uUMsckSA&feature=related
thanks.
Feb 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
After hooking up line wires to motor and load wires from water heater to load terminals,diasgram shows jumper wires from terminbal 1 to terminal 3 and terminbal 2 to tertmninal 5. voltage is 240.thank you ...
That is correct.
LINE 1 (incoming hot wire from source or circuit breaker) connects to terminal #1 then jumps over to terminal #3 using the _same_ gauge wire.
LINE 2 (other incoming hot wire from source or circuit breaker) connects to terminal #2 then jumps over to terminal #5.
The LOAD (outgoing to water heater) then connects to terminals 4 and 6.
Aug 09, 2010 | Intermatic EH40 - Electronic Water Heater...
Needto connect water pipe to mains model number
run 1/4" water line from source and connect to water inlet valve on ref. with 1/4" compression fitting with 1/4" sleeve.
Jul 25, 2009 | Samsung Refrigerators
No cold water, Only hot water in showers.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
Jun 01, 2009 | Danze & Single Handle Tub And Shower...
Plumbing connections
Water source. City...New line..."T" the line so cold water services the house and the other line runs direct to the inlet side of the heater. Make sure you are connecting to the line after it passes through a pressure regulator. If you have a pump and water tank...."T" the line after the tank so cold water services the house and run a line directly to the inlet side of the heater. The outlet side gets connected to the main feed for hot water to the house. These do not require a storage tank. It does take a short period of time to heat the water, but once they get to temp they have an endless supply. Make sure you vent the heater if gas. After you get hot water, you can adjust the temp to the required temp according to the code in your area.
Apr 24, 2009 | Water Heaters
Connecting the fridge to the water point
you need to connect your fridge to a constant water supply such as a water main make sure it is a cold water line that you connect to. good luck peyton
Feb 02, 2009 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker line
The plastic water line uses a little brass sleeve that insurts on the inside of the plastic pipe. This allows the compression ring to press down and pinch the plastic to the sleeve. make sure you get the plastic pipe pushed in as far as it will go @ 1/4 inch. pemember your working with plastic do not over tighten it will cut the plastic.
Oct 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
