Question about Toshiba Satellite A205-S4617 Notebook
Startup My laptop will get as far as the windows black screen with the green load bar. It will sit there for hours and never startup. What is the problem?
  • sweetypie042 Dec 04, 2008
    Done this and after doing the restore disk it says it needs to restart. When it tryes to restart it goes back to that screen of loading and never further.
  • 176 Answers
Try to do a clean reinstall of windows
if that does not work than when the comp starts up (after the BIOS tests) press F8 (or F5, i dont remember with one is for XP(i presume this is the OS ! if not the same anyway !)) and try selecting VGA mode - the problem might be do to video drivers, or Safe mode ... log in as Administrator, and try to check if the hard drive is ok, if the computers drivers are installed ...etc ...
try these fore now and give more details if is still not loading. ....
Posted on Aug 06, 2008
Why won't my HP Pavillion G6 turn on after downloading windows 8.1 update?
try disconnecting power supply and removing battery as well then replace both and try again.Is it possible there was a power interruption while update was downloading. have you tried to access the bios on startup (press f9 at start of startup until it goes to bios)and see if all settings are ok
Sep 01, 2014 | HP Pavilion G4 G6 G4-1000 Series...
Some problems in laptop
Have the hard drive tested for issues, from your description it is the harware that is causing the problems.
Jun 27, 2012 | Computers & Internet
Computer turns on and after its done showing loading bar a blue screen appears . the computer then restarts with a black screen showing start windows normal, or startup repair. i chose startup repair
Try running the Check Disk Utiltiy.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 25, 2012 | Computers & Internet
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
My dell inspiron 1501 is stuck in bios about 75%
operating system isnt loading....try booting with a windows boot cd
Nov 21, 2009 | Dell Inspiron 1501 Notebook
Startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Oct 18, 2009 | Dell Inspiron 6000 Notebook
My compaq will start up saying loading files..then it starts to look like its loading up by showing the green bar moving across the screen...then after that nothing but a blank screen...the lights are...
before windows starts press f8 a couple of times to get into safemode.
if windows doesn't load then you probably have to reinstall windows.
If windows does start, try going into msconfig. Go to Start - Run then type in msconfig. click on the startup tab & try to remove some of the start up programs to see if thats the problem.
Oct 11, 2009 | Compaq Computers & Internet
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
Trying to reformat my PC but can't get into BIOS set up.
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Aug 30, 2008 | Computers & Internet
Acer aspire 3000 dropped on floor. Random startup events
theres a good chance that the hard drive platletes and parking head have been damaged, although this is not a huge problem to replace, as long as your screen is working ok, then it is worth replacing. you can access it on the underside of the casing, in the largest compartment, remove all screws and the hard drive will be held in with more screws.
Apr 14, 2007 | Acer Aspire 3000 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
