Question about Cell Phones
I have tried everything imaginable to connect with the bluetooth device and i can't HELP ME
    Problem Solver:
  • 9 Answers
May be ur device is not visible to others,
for this go to the Bluetoothsettings of ur phone make ur device visible to others
enjoy
Posted on Mar 31, 2011
Iphone6 states "connected" to JBL Charge but no sound. Worked fine up until a few days ago. Both show paired.
Are they connected or paired now? Make sure you don't have any other device near that may have Bluetooth on. Like a laptop, PC,or tablet. Try forgetting the device, and reconnecting. If this fails make sure your phone isn't on wifi and cellular. If this all fails. I imagine its not the fault of your transmitter, but lies in the fault of your reciever, the JBL flip. Also, is it fully charged and is the speaker holding a charge? I'm a small Bluetooth speaker junkie, and I'm sorry but I am not impressed with these at all. There are much cheaper, and better made out there, than this one.
Apr 04, 2015 | JBL Charge Wireless Portable Speaker for...
Bluetooth device not discoverable
Bluetooth comes with the belief that everything will simply connect to anything that has bluetooth capability. Unfortunately this is a misconception that I often run into problems when trying to explain to people. I am assuming that the laptop is displaying bluetooth as being on and both devices are in discover mode. Try to put a distance of approx 3 metres between devices, and try to connect. Also try switching one of the devices off then on again or another device that has a different model number to that which you are attempting to connect. Of course if nothing is being discovered then you will need to check that the bluetooth drivers/software is running on your system. If not again go to the manufacturer website and download the software, install it, restart and try again. Hope that helps!
Sep 06, 2013 | Lenovo G570
How can i get get bluetooth driver for intel dg41rqi motherboard for windows7 and windows xp
Greetings - There is no Bluetooth built into the motherboard, so I can't imagine what drivers you are referring to? Perhaps you are referring to a Bluetooth device you want to use with the board? If so you would have to get the drivers from the device manufacturer.
The full spec sheet for the board is located here:
http://www.intel.com/Assets/PDF/prodbrief/DG41RQ-prodbrief.pdf
Regards, Mikeywaf
Mar 03, 2011 | Intel DG41RQ Motherboard CPU Bundle - ...
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Can't get to bluetooth setting on my garmin nuvi 750
The Nuvi 750 does not have Bluetooth capabilities. Simply put, there is no way to connect your phone with the Nuvi 750 via Bluetooth.
Dec 31, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Bluetooth Problem in Lenovo (3000) y410
Bluetooth devices needs drivers before it can work properly in the computer. You need to install but if your computer was configured to plug and play. It should run automatically because bluetooth has direct play. Try to check your bluetooth device when connecting. You might not be able to connect properly that's why it was not detected.
Please post any comment to give you more tips.
Thanks.
Nov 27, 2008 | Lenovo 3000 Y410 Laptop
I cannot use my Bluetooth device - it works only one-way
try changing the phone.....or try a hard reset *2767*3855#
Aug 24, 2008 | Samsung SGH-D900 Cellular Phone
Headset won't get recognized or connect...
when your in device seek blue tooth mode at its start up to seek is on
now on your bluetooth your using
make sure completly off first
then when device is in seek hold the bluetooth headset power down till your device finds the signal it will tell you in 30 to 40 that its found it
if requires pin it is 0000 or 1234 or 12345 this after everything found
thats it all you had to do
Jun 03, 2008 | Motorola Mobility H500 Wireless Headset
Bluetooth wont work
Goto:
spanner - wheel click!
bluetooth -wheel click!
bluetooth disabled - wheel click!
Enable bluetooth -wheel click!
Paired devices
*EMPTY*
- wheel click!
Add device - wheel click!
after the search select the device you wish to connect to...& contiue to follow the on screen prompts & pairing instructions.
Dec 18, 2007 | RIM BlackBerry 7290
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
