Question about Sonicare Phillips Essence Hx5351/46 Toothbrush
My tooth brush keeps turning off after approx 45 seconds. The light blinks even though it has been on the charger all night. I have only had it for about 2 months
My E123CS55GS Electrolux Side by Side Refridge is not working on the refridge side. The "High Temp" light came on, so I 1) checked the door to ensure it was closed tight, 2)Checked Fridge setting- Set at...
when temperture is droping its a good indication it fuctioning properlt but when the refrigerator doesent go down to the desired temt of 37 you may have to clean the coils in back of the refrigerator this can be done easily as it worked for me you can use a aircompresor to blow any heavy dust the unit has acummilated or you can use a soft brisle brush even a tooth brush is good in hard to reach areas.
Sep 09, 2013 | Electrolux EI26SS55GS Stainless Steel ...
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Sharp LC-32SB23U 32 in. LCD TV
Samsung transform ultra "charging" while not on charger
I had the same problem and eventually my phone just wouldn't charge at all. I took an old tooth brush n was cleanin the charging port with it then id blow it out n repeat and honestly after bout a half hour of doing this it is now finally charging.
Apr 16, 2012 | Samsung Transform Ultra
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
What does a red blinking light mean on a makita dc1804 charger?
I would clean the contacts on the battery to be charged and the charger. You can do this with a discharged battery and the charger unplugged usins a small mechanics wire brush,they can be had made like a tooth brush and work well for tight places. Gently brush and then blow out with air. Make sure that battery is firmly seated in charger and if light continues to flash you probably need a new battery. Thank you.
Mar 07, 2011 | Makita Garden
It was working till last night but its not even getting charged now the light is not blinking at all wat do do????
Try cleaning the USB socket and plug. Can use a very soft tooth brush or such like. Then give it another go.
Dec 20, 2010 | Apple iPod shuffle MP3 Player
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
Battery drans even after being on charger all night. new battery and alternator. went though fuses and all ok there. dont know what it could be
Something is staying on after the car is turned off. Try putting in a dark garage and check interior lights,glove box, under hood light, etc. Also keep in mind even new parts can be defective.
Oct 01, 2009 | 2002 Kia Sedona
Kdfwe42655 Sony Picture on approx 45 seconds;
http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=19 <try this and good luck! let me know if it helps...
Jun 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
Sonicare Phillips Essence Hx5351/46 Toothbrush Logo
703 people viewed this question
Top Sonicare Health & Beauty Experts
Dennis
Andrew Taylor
Andrew Taylor
Are you a Sonicare Health and Beauty Expert? Answer questions, earn points and help others
