Question about Freezers
Freezer Defrosting Freezer works fine but occasionally it leaks on floor.
    Problem Solver:
  • 12 Answers
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Posted on Aug 05, 2008
SOURCE:
How do I stop freezer from leaking water
A drain plug is a small hole inside your fridge to allow for moisture to escape. The reason its leaking water is because its not cooling the water to ice or its defrosting the ice to water. make sure the door closes shut and turn it up a bit as it has been very hot recently
Aug 01, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
What to do the ice bridge is too thick
First De-Frost. The same process can be speeded up by opening the Fridge Doors, remove the electric plug from the socket(i.e. switching off power) and wait for all ice to melt, drain the residual water and Re-Start the Fridge.
Regular defrosting(say Once in 10 days) will ensure there is no ice built-up!
Apr 12, 2012 | Freezers
How do I defrost the unit?
You give little to go on as to what you have. Self-defrosting? Freezer/refrigerator combo?
Assuming you have an old-style, non-defrosting freezer, the only way to do it properly is to empty it and turn it off until the ice melts. Open the door(s) and surround the base (floor) with towels to catch the water.
UNDER NO CIRCUMSTANCES USE ANYTHING HARD OR SHARP TO REMOVE THE ICE!!! The rule is to use nothing sharper than a Q-tip.
When the ice is soft, a plastic mallet may help in knocking the ice free, but gently... very gently.
If you cause a leak in the (probably aluminum) evaporator, have enough money budgeted to replace the machine. Repair costs would exceed the replacement cost in most cases.
When done defrosting, re-start the unit and let it run for 24 hours to ensure that the unit can attain temperature... not doing this puts your frozen product at risk.
Jun 18, 2011 | Freezers
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Woods Upright Frost Free Freezer
its just the machine defrosting itself, let it wee until its empty, then switch back on and let it settle for 24hours before loading up with beer etc......
May 27, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Freezer "leaking" cold water on floor
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Dec 06, 2008 | Frigidaire 14.1 cu. ft. / 399 liter...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire upright not cooling
It sound like you had a freon leak, you REALLY need to get this checked by a tech. if you are leaking freon it can be dangerous.
Jul 31, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
135 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
