Question about Brother Office Equipment & Supplies
We can get the black ink to work on its own. we cant get all black copies the paper will come out with nothing on it. when we make a copy in color the black will show. recieving a fax the paper comes out plan. how do we fix such a problem?
  • 512 Answers
Check the properties tab for the printer in the "START> DEVICES AND PRINTERS> (select the right printer)> (then right-click and select "properties")> the tab is likely set to "all black" or "gray scale" or something like that. reset to the settings that you want to use. good luck!!
Posted on Mar 31, 2011
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
Hp F4180 No copy to Plain paper
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
May 30, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
BLACK INK COPY FUNCTION
Something is definately damaged and with the low cost of printers and the high cost of repair I would recommend just replacing it. Hope you find this helpful,
George
I'm also disabled with a broken neck :-(
Jul 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
