Question about GE Hammering
I just a GE load center/sub panel on my garage with a 60 amp back-fed main breaker. I purchased a retaining clip (part # THQLRK2CP) and am looking for instructions for how to install this retaining clip so that it locks the main breaker in place. I believe I have it installed correctly; however, it does not seem to hold the breaker down. Do you have a photo or instructions that indicate how this clip is to be installed? Thanks Fred
  • Steve Apr 07, 2011
    Hi Fred
    I just found your question - and see it has gone unanswered for 8 days. You are correct that the NEC requires back-fed breakers to be secured to the load centers. Are you still looking for help with this - or did you figure out how to install it?
    If you're still stuck, could you tell me the GE catalog number of both the of the 2 pole / 60 amp breaker and the load center you are using? GE makes a *ton* of electrical products so this info will help me cut through the stuff that doesn't apply. I don't use GE products that much, so I have to look at images of the bracket, breakers and panels to see how they would work together. I'm sure I can get you the info you need to make this installation right if you can provide the numbers I asked for above.
    Thanks,
    Steve
I also had this problem and was eventually able to get the following information from GE.
1. Shut off power to the panel (I have to state the obvious).
2. Install a double pole breaker in slots 1 and 3.
3. Locate the small plastic peg between the two main power lugs. My terminology may be wrong, but this is where you would feed power if not backfeeding.
4. The hole on the 90 degree tab of the retainer then fits over the plastic peg. Orient the retainer so the upside-down "J" portion fits over the breaker lip.
5. Press a lock washer over the plastic peg. This holds the retainer in place.
6. Feed your cable into the breaker and tighten.
7. Label main power shutoff as required by code.
8. Power on.
Posted on Oct 13, 2011
  • 70 Answers
These breaker holders are not the tight fit one might think,the manufactures only provide these things for code,you prob have it in correctly
Posted on Jun 13, 2011
I purchased a GE Power Mark Gold 100A load center to use as a sub panel. I need help with the proper setup please?
There should be a diagram inside the box showing correct set up. If in doubt, have an electrician connect it.
Jun 19, 2017 | GE Electrical Supplies
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Wantneed diagram for G.E. TL412CP sub panel
Do you have any wiring in the panel already? The green or bare copper wires will go the ground bar which will be screwed directly on to the inside of the box. The ground bar will be in contact with the box. If the mains are wired into the main lugs the main ground will have a green stripe or it may be bare multi strand aluminum. All ground wires go under screws individually on the ground bar. The white wires go onto the neutral bar. The neutral bar will be affixed to the inside of the box on plastic isolators that do not allow contact with the metal panel. The main neutral will have a white stripe or it may be solid white. The neutrals will go under individual screws. The hot wires will now go under the screws of the breakers. All screws must be tightned firmly but not as tight as you possibly can. The hots will be black or red. The wires should alternate black, red, black, red. Begin with black on the top two breakers the one left and the one on the right. The hot wires will be either black or red.
Feb 27, 2012 | General Electric GE 125 Amp Indoor Main...
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
How do I run from a 100 amp main panel to a 60 amp subpanel, 125 from my house to the garage
See 60 Amp sub-panel image
Above image shows drawing of 60Amp sub-panel located next to main panel. Drawing shows #6 wire... 125' distance to garage calls for #4 wire. I ran #4 to my barn and have no problems.
Give thought to how many new breakers you want at garage.
See photo of subpanel that holds three 240V breakers
Using drawing as a guide. Replace existing 240Volt breaker with new 60 Amp breaker. Two hot wires connect to new 60 Amp breaker. Neutral connects to neutral busbar.
More space: You can free up space in main breaker box using a tandem breaker. Or by doubling up 2 lightly used 120V circuits onto one breaker. Do not double-up on 240 Breakers
Conduit: You want PVC conduit large enough to fit three #4 wires. Bigger conduit is easier to pull wires ... and maybe later ethernet wire, or alarm wire etc.
Ground wire: You can put a ground rod at garage and run #6 bare copper between sub-panel neutral-busbar and ground rod. Attach ground wire firmly with grounding clamp.
I want you to check with local electrical supply for exact code in your area concerning conduit requirements, grounding, and wire size. Tighten all lugs very tight against wire.
Oct 03, 2010 | Siemens 100 Amp Main Breaker Renovation...
I am installing a sub panel in a detached building from my house. Which is 100 ft away. I plan to have four separate circuits. One that will service a ceiling fan and 3 for plug ins that will only run a TV...
You could use 6/3 with ground. You must take an equipment ground conductor along with your current carrying conductors. Still drive a ground rod at the building, and add a seperate ground bar in the sub panel. Connect your equipment grounding conductor from main building along with the equipment grouding conductor to the ground rod. Do not bond the neutral in the sub panel to ground. Be aware you will still have some voltage drop, so a 220V air conditioner might be better.
Sep 10, 2010 | General Electric GE ELECTRICAL TQD22200X2...
We have a Cutler-hammer CH2100 main breaker that is very old and started arcing in the box and cutting out the electricity at any moment that it wanted to. I found out that the clips on the back were not...
I was able to go online and locate numerous sites that offered the ability to order the CH2100 and also the CH2100x main breakers. You could also take the breaker to an electrical supply and see what they have to offer as a replacement, but be sure that the connectors in the panel are not damaged before purchasing and installing a new breaker.
Jan 24, 2010 | Cutler Hammer 125 Amp Main Lug Indoor Load...
Ground rod placement
If this is a Sub pannel that is fed from a main pannel then you don't need a ground rod for it, but you do need to run a ground wire in the cable that feeds it. So if it is fed by a 220 volt breaker in the main pannel it needs both hot wires, a neutral, and a ground wire in the cable.
Also when you get to the pannel do not attach the ground bonding jumper to the neutral bus in the sub pannel. each of the 4 wires will be seperated at the sub pannel.
Presto.
Aug 24, 2009 | Electrical Supplies
AC Breaker trips and AC Fan turns slow.
Sounds like you have a bad capacitor for your squirrel cage fan , now as for the a/c unit sounds like you have a direct short in compressor to ground or leg to leg , check all wiring to make sure that it is not grounding out or melted together.
Jul 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Hammering Logo
712 people viewed this question
Top GE Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Hammering Expert? Answer questions, earn points and help others
