Question about Sunbeam Heating & Cooling
The Auto Off light is flashing and the fan will not turn on
    Brigadier General:
  • 4,736 Answers
It may just need to reset itself. Turn the Master On/Off switch to OFF and unplug the unit. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF switch to ON and set the heater as you normally would. That time out, should give the controls time to reset themselves.
Hope this helps you solve the problem.
Posted on Mar 31, 2011
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
May 12, 2016 | Office Equipment & Supplies
Hazard warning lights activate when engine is turned off and car is parked. Any ideas please?
try pressing the hazard light button again as it may have been accidentally pressed
if that doesn't help take it to an accredited auto electrician for a proper diagnosis as there could be a problem with the immobilizer that flashes the light when activated or deactivated and is continually flashing the light outside of the hazard switch circuit
Mar 01, 2016 | Replacement 2008 Audi Tt Single Fan Oe...
Sony kdf e50a10 no picture 4 red led flashes
Made around 2005---It should have a rather large fan at the lamp---there is a thermal sensor there that looks somewhat like a temp sending unit in a auto----there is also in the wire harness a thermal fuse but that is good based on your blink code.
I would not alter the design of the fans but make sure they are not that dirty--they will slow down if dirty.
My focus would be on either the sensor for temp for the lamp being bad or the fan there being bad---both are possible.
May 28, 2012 | Sony Televison & Video
Green light flashes for about a minute, fan does not turn on and there is no picture or sound.
unplug all cords and cables from tv, then unplug tv, wait about 5 min, plug tv back in this resets, the "brain" if samething ....see if your bulb is glowing, or tv is hot to touch...always clean the breather slots or holes so fan can push or pull cool air..most of these tvs have a auto shut off for safety if fan has faulted out.....you might just have a DONE fan unit.
Jun 27, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
Computer wont turn on or off
power unit PSU dead is there a fan motion ? beware of PSU that sleep in the night ... mine did it and destroyed the syste, also the auto safety may have dumped out and it will not resume unless the system is repaired, could be power or maybe an internal chip Memory short, processor dead, fan stopped inside ... never run without it there may be a loose connection stopped fan . Mike
Jun 13, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I can't remember how to turn the flash back on to auto flash?
  folloe these steps
camera<settings <Flash< turn it on .    or camera<more<flash<turn it on
Oct 16, 2007 | Sony Ericsson K750i Cellular Phone
Heating & Cooling Logo
127 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
