Question about MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard
I have a computer I brought it last month it is AMD Athlon II 2.9 Ghz and my board is MSI K9N6SGM. My problem now is when I try to turn on my computer there is no Video that appears in the monitor but the LED and Blower of the CPU is still working.. I tried to troubleshoot.. First thing I did was I took the memory card on the CPU and when I turned it on there is no beep. Do you thingk the problem is on the mobo.. Please help me guys!!!!!
  • mark01_chelz Mar 31, 2011
    Thank you guys for the advices.. Hope I will fix my computer.
  • 2,427 Answers
Its the mainboard but chances are its ok and just needs flashing.
1.) locate the battery on the man board
2.) remove it
3.) remove the memory module
4.) press and hold the power button for 10 seconds
5.) replace the memory
6.) replace the battery
7.) turn it on and load the default settings for the bios.
if the above fails
2.) remove it
3.) remove the memory module, remove the heat sink, remove the processor
5.) replace processor and heat sink, replace the memory
try that and let me know how it turns out, I'm 90% sure it will fix your problem, ps remember to unplug it first.
Posted on Mar 31, 2011
Testimonial: "Thank you.. Actually Im at work right now and my computer is in my house.. I will try to fix my computer when Im home.. I will let you know how my pro"
  • 374 Answers
If your computer powers up (the fans turn on) but the monitor screen stays dark and /or the operating system does not load, Some component inside or attached to your personal computer has failed. These include the monitor, power supply, CPU, motherboard, hard drive, display adaptor, memory etc. If you have the required tools and test equipment , and you understand how these components work you can test them and determined which component has failed. Otherwise, you need to have a computer technician determine what your problem is.
I'm sorry that I can't help you more, but repairing computers is similar to repairing automobiles . If my car will "turn over" when I turn the key on but will not start, I could replace the fuel filter, fuel pump, coil, ignition computer etc. until I found the problem. However, I don't have the parts or tools or the test equipment to test the parts with, and I don't want to a guess at what part has failed and spend money buying replacement parts which may or may not solve the problem. I take the car to my mechanic for repair.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Amd athlon ii x3 450 best compitible mother board
asus makes the Best mainboards in my opinion, All AM3 boards. You get what you pay for so it's worth spending a bit more to get a good mainboard.
Example: ASUS M4A88TD-V EVO/USB3 is a really good option, however I myself would pair this mainboard with a AMD Phenom 2. Though your X3 450 will work well in this mainboard too.
The best compatible mainboard would be the ASUS Crosshair IV Formula or Extreme edtion, however your CPU will be a bottle neck in the system.
The ASUS M4A88TD-V EVO/USB3 is really good looking and it performs really well too.
You could go for an ASUS 785/790/870/880/890 North Bridge chipset AM3 Socket.
You could even purchase an AM3+ mainboard that will support AMD's new Phenom module CPU's.
Go to www.asus.com and check out the AMD mainboard range that they produce.
Take care!
damnor01
Feb 11, 2011 | AMD Athlon II X3 450 / 3.2 GHz processor
What motherboard will replace a msi k7t turbo2?
This is an obsolete part; as such, you will have a hard time finding it at any retailer, whether brick and mortar or online. However, all hope is not lost-try E-bay
http://computers.shop.ebay.com/i.html?_nkw=socket+a&_sacat=1244&_trksid=m270&_dmpt=Motherboards&_odkw=&_osacat=1244
You will have to look for a board that supports S-Dram memory, because that is what your MSI K7T Turbo2 uses.
My advice would be to skip this entirely; I would replace the whole board/CPU setup, and pick up some memory. You can get an Athlon II quad core and mobo for $165.98 USD (Asus /AMD). Pick up 2 GB of Kingston DDR3 RAM for $56
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134790
and you essentially have a whole new system for $222
Just my opinion on this-I don't think that spending the amount of cash you would have to in order to replace an obsolete board is worth it.
You might try this, instead:
AMD Athlon II x2 Regor (2.8 Ghz, dual core) @ 56.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103688
ASRock M3A770DE AM3 AMD 770 ATX AMD mobo @ 59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148305
Total $174.97 + shipping USD
Given you 3 ways to go and my advice-good luck!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
Crucial 2 GB Ballistix 240 pin DDR3 1600 Memory for $57.99
Feb 03, 2010 | MSI K7T Turbo2 Motherboard
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Dec 15, 2009 | Computers & Internet
I have lost my motherboard driver CD( AMD Athlon(tm)xp 2000+ 1.68 GHz,),from where i can download?. plz help?
If your motherboard is ASUS then you can go directly to www.asus.com and search for the k8mv motherboard drivers or
if its a MSI board the go to www.msi.com
May 15, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I have AMD Athlon 64 Processor 3700+ not reading at 2.40 GHz
Try going to Control Panel -> Power Options and changing the Power Scheme to Always On.
Mar 26, 2009 | Computers & Internet
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard Logo
185 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
