Question about MSY-A17NA Air Conditioner
I have 200psig on hi-side while my lo-side is negative zero compressor is getting hi-temperature. all systems are clean. inject refrigerant R22 almost 3 kilos. still no cooling or proper condensation on the condenser
  • Mitsubishi Master
  • 43,501 Answers
you have a plug in the cap tube which is the expansion device that the Mitsubishi A/C units use...
you MAY be able to pull the dirt out by removing the refrigerant and pulling a vacuum on the unit..this will not always work but it is worth a shot...
if it does not work, then the cap tube will need to be removed and replaced...
Also be aware that Mitsubishi does not recommend the installation of any filter/dryers other then their own...
heatman101
Posted on Mar 31, 2011
Testimonial: "great advice thanks... need to replace cap tube "
What are the running compressor pressures H&L
Thats a hard question to answer! what Type of refrigerant is in it? R-22 or R410A? If its R-22 you want to see about 60-65# low side and 225 -240 high side. those can vary with outside temperature. R-410A look for 120# low side and 450-475# high side. DO NOT USE R22 MANIFOLD SET ON R410A SYSTEM!! IT WILL NOT TAKE THE HIGH PRESSURES AND COULD EXPLODE.
Aug 12, 2014 | Intertherm P3RA-036K Air Conditioner
Compressor shut off for no reason
You need to to determine the superheat and subcooling to check for the proper operation of your system when the compressor is running. I ran into a case just yesterday, the breaker kept tripping. Unit had the same readings as yours. This one had a subcooling of >25 degrees and 0 degrees superheat indicating unit was overcharged. I took an extra 8 pounds of r22 out of the system. During the investigation I also determined the filter/drier was blocking the refrigerant flow causing the technician to overcharge the unit. To check filter/drier performance all you need to do is measure the upstream and downstream temperature. The difference should be less than 2 degrees. This one was 7 degrees indicating it was metering flow. If your compressor stops operating before determining superheat and subcooling, you can get a professional tech to recover and weigh out the refrigerant in your system. You can look on the nameplate data on the side of the outside unit and see the ounces of refrigerant it is charged. If the compressor is operable go ahead and adjust charge by recovering the excess refrigerant into a recovery container for that refrigerant. Normal superheat and subcooling is normally around 10 - 15 degrees.
Hope this helps
Jun 20, 2014 | Goodman CLQ36AR49 Air Conditioner
What kind of freon does this model refrigerator need
Most all Domestic refrigerators these days use R134 refrigerant such as yours most likely uses. The easiest way to assure what type of refrigerant would be to access the compressor area and look on the side of the compressor. All compressors have a tag showing what type of refrigerant is used in the unit. If you have any further questions or if you need a detailed schematic showing how to access the compressor area message me back your complete model number and I will provide one for you.
Thank you,
Rick
P.s. Never assume a unit uses one type or another types such as R11,R12, and R22 are being phased out due to government regulations on the hazzardous chemicals found in refrigerants such as these. It is always best to check the compressor for the labeling tag.
Jul 01, 2012 | Sub-Zero 561 / F
Freezer temperature cannot be lowered. now at 57 degrees
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 10, 2010 | Sub-Zero 661/F Side by Side Refrigerator
Freezer temperature seems excessivley cold
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Nov 16, 2010 | Sub-Zero PRO 48 Side by Side Refrigerator
I have a side by side that does not hold temperatures. It stays at zero then goes to 10 degresss than back to zero
That is normal operation. The temperature will increase when the compressor is off. When the compressor cycles on,the temperature will decrease.
Sep 28, 2009 | GE GSS25JFM Side by Side Refrigerator
Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
Overheating condensors
Bad compressor. Anytime a compressor on anything gets to hot to touch that is a sign that the piston is applying to much pressure to work which in return causes the compressor to go bad if not caught right awya
Jun 03, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezer temperature dropping/digital display reading zero +/- 2
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Mar 29, 2009 | GE PSC25NGS Side by Side Refrigerator
MSY-A17NA Air Conditioner Logo
151 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
fordexpert
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
