Question about Stanley Air Tools & Compressors
Air leak from trigger in bostitch pneumatic stapler
  • 41 Answers
You need to replace rubber o ring on the trigger shaft pretty easy fix o ring is real small to deal with but doable automotive part stores usuly have assorted size in trays you can take old one out match its size .
Posted on Mar 31, 2011
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
Stapler will not build pressure
did you oil it? It is an oil free, i oiled mine and that happened. i ended up taking it apart and clean out the cylinder , it is easy to do..just use a clean rag no cleaner it might ruin the seals
Jan 16, 2014 | Stanley Bostitch 2 in. Pneumatic Lathing...
Stapler losing air around trigger is this a o ring problem?
The problem is most likely the trigger valve. P/N FA205BA1 any Bostitch dealer should be able to get it for you. Its a complete cartridge that slids into the gun frame, unfortunatly you can't just change the o-rings.
Dec 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
When I pull trigger air is escaping around the trigger and nailer will not engage
you need a new trigger valve assembly, there is an o ring that has split. Contact Bostitch for a replacement part.
Oct 08, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a Bostitch SB-150SX pneumatic stapler. It's about 5 yrs old. I've been using it for the last couple of days without any trouble. Then yesterday, it would not shoot. When I pull the trigger air...
Are you using air-tool oil before each use? Water or debris coming through the air hose can cause like problems. Try installing an in-line filter. Hope this helps!
Aug 13, 2010 | Garden
I have a bostitch ridge runner that leaks air badly out of the trigger and wondering how to take out the plastic trigger in the gun. Also what would be the cause of the air leak
The air leak can be one of a few things. FIrst make sure that you have added some pneumatic oil to the air stream. This will lubricate the o-rings and make a tight seal. If that fails to resolve it, repalce the o-rings. (kits available for around $20). Next, woul dbe the trigger assembly itself. These triggers wear over time and are easily replaced.
See the website below for parts and a good diagram of the construction of the gun. You should be able to replace the parts by following the diagrams.
http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CO6tkb2y6KICFciA5QodOlL9xg
Please note that the exactmodel number is required to get hte correct diagram.
Hope this helps,
Dan
Jul 12, 2010 | Stanley Factory Reconditioned Bostitch...
Leaking air when trigger is depressed
This is an indication of a defective seal. Try adding a little pneumatic oil to the gun and triggering it a few times. Sometimes all it is is a small leak in the o-ring because of a lack of lubrication. If not, then try replacing the o-rings (kit available for around $20). The next possibility is the trigger itself. I have replaced the trigger assembly on mine once thus far.
Good luck,
Dan
Jul 06, 2010 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Bostitch stapler T40S2 has air leak at trigger. I need repair instructions to replace orings
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Jun 18, 2009 | Air Tools & Compressors
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Mar 11, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
246 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
