Question about Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool WFW8300SW Duet Sport Washer. We have been having problems with F-25 error codes coming up on the normal, quick wash and whitest whites cycles. It will run through a delicate cycle fine, normally needing additional drain and spin cycle at the end of the delicate cycle. We had a repairman come out and empty the catch next to the pump and say that was our problem and it was fixed. He left and it wasn't fixed. We have cleaned out the pump area, dismantling it and getting rid of the gunk build up in the pump, that helped the grating noise the pump had been making, but we are still getting F-25. When I try and do a clean washer cycle I get the rL code, when there is no clothing in the washer. I have pulled off every tube I can find and made sure there were no obstructions blocking anything, nothing there. I ran the Diagnostic Test and I am not sure what everything means. During Rinse/Spin, flashing light. During Clean Washer, A on Screen and flashing light, during delicates, 2 on screen and flashing light, during Quick Wash, 1 on screen and flashing light, during Normal/Casual, 1 on screen and flashing light, during heavy duty, black screen and flashing light. During whitest whites, flashed once and then the door unlocked. We are thinking it is possibly a MCU or CCU or Pressure Switch problem, but I would like a little more input before I spend money on parts. Thank you for your time!
  • 1 more comment
  • tamiknits Mar 31, 2011
    It looks like it was a loose connection of a wire under the tub at the motor, it was a connection I had not found before. So I am trying a load now and hopefully it makes it all the way through, otherwise it looks like a new MCU for us!
  • tamiknits Apr 02, 2011
    Ok, I replaced the MCU and now the washer wont even start, it just door locks and I can hear clicking but it won't move on. And, the door is stuck/locked even after pressing cancel and unplugging the washer.
  • tamiknits Apr 03, 2011
    It looks like the top connection, the one with the 3 blue wires, the plastic piece that holds it into the MCU broke, can we get a plastic piece to replace or do we have to buy the entire wire harness system?
  • Whirlpool Master
  • 8,220 Answers
Aha! F25 Motor Tach error Bad MCU (motor control unit) or broken wire.
Do we do the swap parts thang or try to trace down the broken wire? Before ordering expensive parts go along the rail where the wiring harness is most susceptible to vibration and look close for signs of distress.
Posted on Mar 31, 2011
  • Dan Webster
    Dan Webster Mar 31, 2011
    Lets get our nomenclature and service manual in order. Click HERE
  • Dan Webster
    Hope yall git er dome! Let me know.
Whirlpool washer duet sport ht MOD # WFW8300SW02
did you try to diconnect it from wall?
try to disconnect it.... wait for 5 minutes and try to connect it again and try if same problem still occurs....
Jan 13, 2014 | Washing Machines
Whirlpool duet sport model WFW8300SW Have error F-22 and F-28, how to solve it? Thks
Relates to an electrical/electronic problem
Try the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Dec 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
