Question about KitchenAid Dishwashers
My dishwasher ran good amonth ago .Today when I tried to run it ,it only runs in the dry position. What could be wrong?
  • KitchenAid Master
  • 12,061 Answers
Http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Hi, well to assist you to troubleshoot your problem, i have given you a site above, that will step you through, how to troubleshoot and hopefully resolve your problem. If you do wish yo DIY also one MUST obtain a service manual, they may be able to be found on the 'net, or from the manufacturer.
Unfortunately, with just this symptom, it's pretty hard to tell exactly what's wrong, other than it maybe a sensor, the door switch, the pump, the inlet valves, the "Brain" the... the... you get the idea.. as really most "Faults" simply stop it from working, leaving it mutely idle.
However first have a look at this below,it may or may not apply, but also may well be worth a go... I leave it up to you.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle.This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
it is my professional recommendation, that if you cannot or do not wish to DIY, then to get the best and cheapest result you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Of Your brand Model number, in your case. Ask them, for a referral to an authorised servicing center, where you then FIRST, ask ONLY for a "Quote" as to the cost and type of repair. Now, when you get the information you want, then you can decide as to repair of replacement.
Posted on Mar 31, 2011
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But...
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Apr 21, 2013 | Dishwashers
There are soapsuds in the bottom of the dishwasher when the cycle is done
This sounds like the dishwasher got the wrong type of soap. It is a real problem to get the wrong soap rinsed out..follow the directions given by the repairman..it may take 5 or 6 cycles... The jet dry is just an extra in this issue...it will be okay when the soap is fully rinsed out.
Feb 02, 2013 | KitchenAid Architect? II K SERIES KUDK03IT...
Replaced timing belt and car won't run
You had better check the timing belt again, you may have done something wrong and it skipped teeth.
Sep 04, 2012 | 2001 Volkswagen Beetle
Problem with 800cc suzuki intruder 2002 2002 suzuki intruder 800cc amonth ago i changed all fuilds and brakes also plugs and filter brike ran really good yesterday a couple buddies wanted to go riding
when i shut off my 2002 suzuki motorcyle it run perfect then went to start i and have no power battery good have no light on dash no head light brrake light everything is dead what could be wrong can you help with a idea thank you dave
Mar 26, 2012 | Suzuki Motorcycles
G865 keeps draining during ever cycle
The selenoid that opens/closes drain function id burned out. Your local appliance parts store can provide a replacement selenoid and tell you exactly how to replace it.
Jan 05, 2012 | Miele 24 in. G646SC Plus Free-Standing...
Kenmore Dishwasher Model 665.11643300 Cycle will not run. Normal Wash light blinking Cancel light will also blink (but can be cancelled by holding button down) I tried shutting down the power and...
I will look a bit further in detail about your dishwasher problem. I am assuming you have checked the inlet water tap to the dishwasher is turned on.
Sep 14, 2010 | Dishwashers
Water is not going into my dishwasher --worked for 13 months fine and now having a problem. When I turn it on the motor runs and rattles - louder than before, but no water is going into the dishwasher. We...
try running a diagnostic run on the washer. Push heated dry, normal, heated dry, normal on your cycle selection panel. After you push that sequence all the lights will light up and then it will go through a test run. This fixed my washer that had the same symtoms as yours. For some reason the diagnostic run reset the washer and it ran like new. I also checked to make sure the overfill float in the bottom of the washer could move up and down freely. It is a small white disc float. If it is stuck in the up position your washer won't fill up. Besides those suggestions, my level of mr. fix it knowledge is limited. I hope this helps.
Jan 11, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Locked timer knob in GE Nautilus dishwasher
I ran into this problem earlierr today ....Check the float valve...it is a round looking device in the front (usually) of the DW...if this gets stuck it will (or may) get stuck in drain or in assist dry mode...push it up and down you should here a clicking noise. Take it out and see that there is no debris in it ...if so clean it ..and replace...then try the Dw.
I hopr this helped....good luck....thanks for rating my effort...The Fang.
Feb 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
62 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
