Question about GE 106766 Bagged Canister Vacuum
I have a short in my hose for the GE 2 motor canister vacuum model106766 where do i get just the hose to replace it
  • 710 Answers
Here is a website for parts for your vacuum: http://www.appliancefactoryparts.com/vacuumcleaners/brands/ge/106766.html#Other%20Parts
I hope this helps. I was confused by your statement that you have a short in your hose. Are you saying that something is wrong in the motor or that you need a new hose for the vacuum? The above website whould get you a hose for the vacuum. For the motor, Do a google search for the GE homepage, then click on the customer service, or support tab.
Good luck,
Hope this helps, if it does, I would appreciate a vote or comment. Thanks,
Handie Andie
Posted on Mar 31, 2011
I cannot find the short cord that goes from the canister to hose anywhere and it needs to be replaced...can u help me find the part model 106766
I believe you are looking for this part number: E-71986-1 and they have it at
www.ApplianceFactoryParts.com , put the part number in their search box and it should come up. Cost is about twenty dollars including the shipping.
Jan 24, 2011 | GE 106766 Bagged Canister Vacuum
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
It acts like it has a short in the hose you can hear the motor running and then it will quit. Moving the hose around you can get it to turn back on.
Hello. There is either a short or a poor contact at some location within the hose. In order to fix this you may have to replace the power hose. Joe
May 01, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
The power head has developed an intermittent, but frequent, electrical short. Is there an easy way to assess where? Or is this a matter for a repair shop.
Greetings,
A majority of the time when this happens, it's caused by the hose having a short in it. You'll need to first identify what the source of the short it. To do this, turn the power brush on, and then swivel the hose on both the end before the handle, as well as the end that plugs into the vacuum, can you get the power brush to cut on/off for you from here? If yes, then you'll need to purchase a new hose. You may purchase this hose directly from Sears, however when you buy the hoses through Sears you have to assemble the hose yourself, which is very challenging. An easier way for you to replace the hose, is to purchase a Panasonic canister hose. There are two types of hoses, a 2 wire hose, and a 3 wire hose that fit most Kenmores. When you take the hose out of the canister, look on the part that plugs into the canister, how many prongs do you see here? If 2 then you'll need a 2 wire hose, if 3 then a 3 wire hose.
If you are not able to locate the short in the hose, then you may have a short either in the wand, or the power nozzle neck wire. For the wand, put one foot on your power nozzle while it's running, then pull up and down on the end of the wand that plugs into the canister, as well as the end that the hose plugs into. If you can get the vacuum power brush to cut on / off when you're doing this, this indicates your wand is bad and needs to be replaced. If it doesn't cut on / off, remove the wand and hose from the vacuum completely. Now look where the wand connects into the power nozzle. You should see two electrical prongs on the neck of the power nozzle. Do you see any burns, or black marks on the prong, or the plastic part that it comes out of? You can also test this part by turning the vacuum's neck to the left and to the right as if you were turning the vacuum.
Hopefully this helped you. If you need further help on figuring out which part is bad, please just use the clarification request here on Fixya, and I'll be happy to try and diagnose this further with you.
Thanks,
Chris J.
GoVacuum
Mar 25, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
GE canister vac 106766 power not going to brush head
Try checking the hose connector cord (short cord from bezel outlet to hose). Also, check the prongs on on extension wands.
May 19, 2009 | GE 106766 Bagged Canister Vacuum
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Roaring vacuum
Good day,your problem seem that it is plug if you have no suckiong ,place the hose on the exaust that should un plug the hose,or the motor has had some dirt et it and plug the intake ,that is why it roars try this,later
Aug 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Oct 07, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
GE 106766 Bagged Canister Vacuum Logo
95 people viewed this question
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
T bone 1963
Are you a GE Vacuum Expert? Answer questions, earn points and help others
