Question about Kitchen Appliances - Others
Where can I get a ribbon cable for the Littermaid LME 9000?
How to register my littermaid litter box
you should be able to through the link provided Warranty Registration
Sep 15, 2014 | Cats
Littermaid LM980 Turns itself off
The other appliance, e.g., a motor driven one, may be causing the box to malfunction. You may have to use a dedicated connection to get proper results.
Mar 06, 2014 | LitterMaid LM980 Mega Self-Cleaning Litter...
XNon functioning littermaid LM980 mega
Common problem with Littermaid boxes. Try a better brand of clumping litter. Try using a little less litter. And you can help the rake lift up by slowly pushing on it with something, giving it more strength. I had this problem and found that if I "helped" the rake return to its normal position, it would work most of the time, and then need "help" every once in awhile. I actually gave up on littermaid type boxes...they just don't work very well.
Oct 29, 2012 | LitterMaid Lm980 Mega Self-cleaning Litter...
Where is the serial number on my canon mark Ii pixma 9000
Lift the door as if to replace your ink cartridges and the SN is on the ribbon cable that is held to the printer on the right.
Jul 15, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
We had Sampo LME-26X8 LCD get snow at screen when is go TV & VCR or DVD please tell me what wrong Thanks
Check connections to make sure they are tight. If using coaxial cables especially.
Most likely, you have routed through your VCR and it is causing snow even when turned off.
Jun 12, 2010 | Sampo Model LME-26X8 Television
Sampo LME-17S1 TV/Monitor w/RC-235B Remote-V-Chip - No Code
Master V chip over ride code is 8,4,8,4,100 (use the 100 button not 1,0,0) you should be good to go!
May 23, 2009 | Sampo LME-17S1 Television
I've lost the remote and need to switch from "over the air" to cable mode.
Best to have the original remote. Remotes.com seems to be the only people selling the original remote. Not cheap though.
Here's the link:
http://remotes.com/store/sampo/lme17s3.html
I believe this is the only way to solve the problem.
Apr 26, 2009 | Sampo LME-17S2 17 in. LCD Television
Error 11 what is mean
ER 11 means of ribbon feed error.
please check : ribbon feed motor , ribbon feed ic driver motor and main board .
Apr 24, 2009 | Epson DFX-9000 Matrix Printer
Looking for schematic for a Behringer MX-9000. Mike preamps blowing out badly. Out of 24, only 9 are good. Also looking for anyone who sells parts for this board, specifically the ribbon cables as one...
If the mic preamp ICs are getting destroyed, there is something else wrong. Look for the correct B+ and B- voltages. I suspect that there is an offset here that is stressing the ICs to the point that they fail. These ICs should be 4558s or something similar and are readily available for low $$. Contact Beringer directly for the ribbon cable.
Dan
Mar 22, 2009 | Audio Players & Recorders
Kitchen Appliances - Others Logo
172 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
