Question about Toshiba 62HM195 62" HDTV
60p8342 i have spider webs on the inside of tv picture screen. how do i clean?
Try to find an area to blow compressed air through to blow the webs away.
Posted on Aug 14, 2008
Spider webs behind screen
It might be that you have more bugs inside, but if you used a chemical to clean this, it's probable that it afftected the tvs functions
Aug 07, 2009 | Toshiba 56HM66 56" Projection HDTV
How do i clean the inside of my 57" projection tv . this is an hitachi flat screen, i have spider webs inside
without knowing the model number; some you can remove the rear cover and gain access with a swiffer type duster and clean the webs out(also clean the lens at the same time) Others: the only easy way is to remove the screen--not real easy if you have never done it before---most outside service techs will be happy to come to your home and clean the webs out; also clean the lens and the mirror.
Aug 06, 2009 | Hitachi Televison & Video
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Spider web inside tv
You need to open and clean it carefully.
  1. remove the back bottom panel
  2. Remove the top back panel (carefully the mirror is on it)
  3. Clean the mirror and the lenses (on the mirror don't use products with ammoniac) "a good tip is to use same staff to clean photographic cameras"
  4. Place back the top rear panel
  5. place back the bottom rear panel
Nov 09, 2008 | Samsung PCH521R 52" Rear Projection...
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 62HM195 62" HDTV Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
