Question about Insignia 2.1 Speaker System (3-Piece)
Everything connected, but no aound - Insignia 2.1 Speaker System (3-Piece)
  • Insignia Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 31, 2011
I have a samsung tv with aound and no pic made checks that i found on the Internet. Found that i have no backlights ao which board do i replace .model # un32eh4003fxza
It is the backlight that is burnt out not the circuit boards, pull it apart and check also where the backlight connects if that connector is burnt replace it also.
Jun 28, 2016 | Samsung Televison & Video
Where do I find the heating element on my Teledyne laars hot tub? I have looked in and aound the control panel, Thanks
There is no such thing as a laars hot tub. They make heaters for pools and hot tubs. The laars is the heater. There is a chance that someone remote connected the thermostat to the heater which would be in your boiler room, or some other remote location, like near the pumps...
Dec 06, 2014 | Teledyne Laars Pool & Spa
Cannot get door to unlock
Remove the four screws from your dispenser, remove cover, there should be a plastic string, either red,yellow or green pull on it and the door should open. Then remove the four screws aound the door 2 aound door hinge then the other side, remove the front cover, it looks like a small goal post. Remove the the 5/16 screws under the lid. Raise top then you will see your latch assembly. oberverve your latch see if anything is broken. You can order a new latch assemby.Part#22004435 list for about $115.00
Apr 04, 2014 | Maytag Neptune MAH5500B Front Load Washer
Hi I got a 2006 2.7 chrysler sebring 4door no convertible n my driver side window sometime goes down n sumtimes it Dont work what can I do n I need a cheep water reservoir
you can find a cheap water reservoir by going to google.com and do a search for "2006 sebring water reserver" and click on shopping. Your winidow are working intermitten, is due to a faulty switch, or dirty switch, sticky switch, (all mine get soda and chips spilled aound mine and ive had to replace twice already lol ) or loose connections at switch or window actuator, or faulty widow motor.
Dec 13, 2013 | Cars & Trucks
Loud blowing noise from turbo when accellerating
Check the clamps aound the Inlet and Exhaust sides of the Turbo, and the Rubber Boots that connect the High pressure Air flow to the Charge Cooler Inlet and Outlet sides and the Boot into the Manifold. Any of these defects will create this sound. Especially look for a Split in the Connecting Boots, which will reduce Intake Air Pressure and Volume, which indicates a fault to the ECM, and susequent warning.
Regards,DT
Aug 30, 2009 | 2001 Audi TT
Dodge Caravan 1996 How do I install a crank shaft position sensor
No trick. remove and replace. Front of engine aound 11:00 position at crank pully
Jul 09, 2009 | 1996 Dodge Caravan
Interior water
most likely the rubber seal aound the door
Jun 19, 2009 | 1997 Oldsmobile Achieva
Altima ran out of gas and wont start anymore
Your clicking aounds like you have a low battery or bad connection. Ck both battery cables at the battery. Remove, clen, inspect and reinstall. If the battery is dead, you may have a charging system problem and your car didn't run out of fuel, The fuel pump quit because of the battery. Good Luck
Jun 03, 2009 | 2005 Nissan Altima
A2300hct no aound
are there power to the output transistors?
Aug 06, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Insignia 2.1 Speaker System (3-Piece) Logo
55 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
