Question about Cameras
Have a keystone dual 539 projector and just purchased a lignt bulb. How is it installed?
First thing you need to know is that the bulb gets very hot while its on. If you handle the bulb with your hands, you may place oil (yes body oil) onto the service of the bulb. If you can avoid hands on placement of the bulb. The bulb will position into the socket in only one directioin. Look at the center of the bulb, it should face towards the mirror that reflects the light to the film gate. Since the bulb is held in place by pressure, GENTLY push the bulb into the sockett.
BEFORE you replace the bulb, you should look at the mirror on this projector. If it seem dirty with dust, you should take a q-tip swab, dip it in alchahol, and clean the mirror. If there is any dust inside the projector housing, use a vacume to suck it off the services. You can pull the lens out of the socket to use a cotton swab to clean both sides. To get the lens out, pull gently on the focus know along side of it, and the lens could be pulled out.
Posted on Jan 16, 2013
How do I correct a trapezoidal display?
This is called keystoning and there should be a setting on your projector that will compensate for this problem. Usually it will be called keystone adjustment or something like this.
Jun 07, 2015 | InFocus IN2104 Projector
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Projectors
Look for a "keystone" option in the menus, or possibly even directly on the remote itself. You should be able to adjust this one way or the other to digitally square up the image at the cost of some resolution and smoothness. Mind that it might instead have auto-reset itself because you moved the projector around also, some of them have an auto sensing function but it never works very well, might as well turn it off and tweak it manually. Also be sure to zero the keystone and physically true it up as best you can using the extendible legs before using the digital keystone to finish the job if necessary.
And thanks for being the first question I've seen out of a run of about ten which was both presented in full and understandable English sentences, and wasn't just something that could instead have been entered directly into google to get an easy answer... :-)
Jan 29, 2014 | Toshiba TDP-T45U DLP Projector
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
I have just replace the bulb and it works fine but in the lower corner of screen there is a message to replace bulb how do i clear this out ?
if I remember right, hold the 2 keystone buttons in and while you are holding them in, switch the projector on and continue holding the keystone in for 20-30 secs.
Jun 28, 2010 | InFocus ScreenPlay 5700 Multimedia...
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Cameras Logo
521 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
