Question about Apple Audio Players & Recorders
IPod 20gb 2004 will not turn off, will not scroll, will not work!!! Help!
  • Apple Master
  • 6,771 Answers
The only option you can try is reset the player because the processor is locked up, all MP3 players have a reset switch located somewhere on the chassis, look for a small hole that a safety pin can fit through, next! push the pin in and hold for 60 seconds to drain any residual charge and reset the processor ic. If it works you are up and running, if not! it is time to consider replacing the item.
Posted on Mar 31, 2011
I accidentally formatted my ipod 20gb software please help.
my ipod says www.apply.com/support/ipod
what's the problem?
Feb 09, 2011 | Apple 20gb Ipod Mp3 Player With Click...
My brother gave me his old apple ipod (20GB). Now I have not used it hardly at all, but today I found it. It has been plugged into the charger for a looooooooonnnnng time (perhaps months) I went to turn...
Well lots of people come across this problem. Try connecting the Ipod to your computer and then press the critical button and the menu button simultaneously. Hold on to it for about 10-15 seconds and you might find your Ipod working.
Sep 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
My apple 20gb ipod it does'nt work and apple logo appear on screen.i do reset my ipod and after that it turns to normal but after a minute it hang up and apple logo appear.
It sounds like you may need a new hard drive for your iPod. The Apple logo appearing over and over can signify that your iPod cannot communicate with the hard drive where your music is stored.
You can find replacement drives on websites like ebay or by searching Google.
Hope this helps!
TechRestore http://techrestore.com/ipod
Sep 19, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
Apple 20GB IPOD 4th generation corrupted
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Mar 18, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
I have the generation one which was developed in 2005 and mine does the same thing. What i do is hold the menu button and center button down at the same time until it resets itself,this should only take nomore than 30 sec. of holding them down at the same time. That should help.
Jan 19, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Itunes for ipod 20gb
Here is the link for the 4.7.1 version of itunes.
http://support.apple.com/kb/index?page=answerlink&url=http%3A%2F%2Fwww.apple.com%2Fsupport%2Fdownloads%2Fitunes471.html&answerid=16777229&src=support_site.more.ipod.earlier
This should work then you should update the ipod with the latest software and then update itunes to the latest version after that. good luck!
Jan 02, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Apple Ipod 20gb re-set problem
My ipod did this. That symbol means corrupted files which probably means you need to format your ipod. Mine also continued to freeze which is caused by a slightly warped harddrive. Open it up by prying loose the edges w/ a guitar pick or butter knife, take a business card and fold it in half and place it between the HDD and the foam to add pressure to the HDD. Should fix your problem.
Nov 15, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Click Wheel
This usually happens if the iPod wheel is defective, sometimes caused by getting in contact with water sometimes simply through wear and tear. If you're out of warranty, There are specialized online tutorials with iPod Repair instructions that will guide you through the steps of taking it apart and replacing the wheel altogether otherwise you'll have to send it to any third party iPod repair service and they'll replace the wheel for you.
Nov 11, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
