Question about Printronix LineJet® P7210 Printer
Diagnostic Menu Version Control - Printronix LineJet® P7210 Printer
What are the codes for Samsung Android phone
Samsung secret code by Mubarak Sulaimon
*#06# - IMEI number
*#0*# - Enter the service menu on newer phones like Galaxy S III
*#*#4636#*#* - Phone information, usage statistics and battery
*#*#34971539#*#* - Detailed camera information
*#*#273282*255*663282*#*#* - Immediate backup of all media files
*#*#197328640#*#* - Enable test mode for service
*#*#232339#*#* - Wireless LAN tests
*#*#0842#*#* - Backlight/vibration test
*#*#2664#*#* - Test the touchscreen
*#*#1111#*#* - FTA software version (1234 in the same code will give PDA and firmware version)
*#12580*369# - Software and hardware info
*#9090# - Diagnostic configuration
*#872564# - USB logging control
*#9900# - System dump mode
*#301279# - HSDPA/HSUPA Control Menu
*#7465625# - View phone lock status
*#*#7780#*#* - Reset the /data partition to factory state
*2767*3855# - Format device to factory state (will delete everything on phone)
##7764726 - Hidden service menu for Motorola Droid
Update x1: More codes!
*#*#7594#*#* - Enable direct powering down of device once this code is entered
*#*#273283*255*663282*#*#* - Make a quick backup of all the media files on your Android device
*#*#232338#*#* - Shows Wi-Fi MAC address
*#*#1472365#*#* - Perform a quick GPS test
*#*#1575#*#* - For a more advanced GPS test
*#*#0283#*#* - Perform a packet loopback test
*#*#0*#*#* - Run an LCD display test
*#*#0289#*#* - Run Audio test
*#*#2663#*#* - Show device's touch-screen version
*#*#0588#*#* - Perform a proximity sensor test
*#*#3264#*#* - Show RAM version
*#*#232331#*#* - Run Bluetooth test
*#*#232337#*# - Show device's Bluetooth address
*#*#7262626#*#* - Perform a field test
*#*#8255#*#* - Monitor Google Talk service
*#*#4986*2650468#*#* - Show Phone, Hardware, PDA, RF Call Date firmware info
*#*#1234#*#* - Show PDA and Phone firmware info
*#*#2222#*#* - Show FTA Hardware version
*#*#44336#*#* - Show Build time and change list number
*#*#8351#*#* - Enable voice dialing log mode, dial *#*#8350#*#* to disable it
##778 (+call) - Show EPST menu
These codes are specific to HTC devices only:
*#*#3424#*#* - Run HTC function test program
*#*#4636#*#* - Show HTC info menu
##8626337# - Run VOCODER
##33284# - Perform field test
*#*#8255#*#* - Launch Google Talk service monitor
##3424# - Run diagnostic mode
##3282# - Show EPST menu
##786# - Reverse Logistics Support
WLAN, GPS and Bluetooth Test Codes:
*#*#232339#*#* OR *#*#526#*#* OR *#*#528#*#* - WLAN test (Use "Menu" button to start various tests)
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#*
This code can be used to launch GTalk Service Monitor.
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* OR *#*#0289#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
May 04, 2016 | Samsung Cell Phones
Tip
Samsung GALAXY phone - Service / Test / Hidden Menu, Secret Codes
How to access hidden functions / diagnostic menu at yours GALAXY.
Popular practices for the software developers is to leave "back-doors" within the code, which essentially allow anyone with knowledge to get into the system at a much deeper level.
This codes are working for Galaxy S2 / S3 / S4 / S5 / Note 2 / Note3.
Very simple and easy tips and tricks. Codes in this video:
IMEI - *#06#
Version - *#1234#
Main Version - *#12580*369#
Battery Status - *#0228#
Service mode - *#0011#
Service / Test / Hidden functions - *#0*#
on Aug 28, 2014 | Samsung Galaxy Cell Phones
Printer stopped during print session. Message Diagnostics Menusc Version Control 46%. What does it mean? What should we do?
That is a boot diagnostic menu and I have no idea how that would have come up in the middle of a print job. I'd reset the printer (turn it off and on) and see what comes up on the display then.
Mar 08, 2016 | IBM Infoprint 6500 Matrix Printer
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
I have a 2006 ford fusion which the radio system
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna
  • Antenna cable
  • Door trim panel(s)
  • Speaker(s)
  • Noise suppression equipment
  • Smart junction box (SJB) fuse(s):
    • 12 (7.5A) (accessory delay feed)
    • 17 (20A) (subwoofer amplifier) (Audiophile)
    • 18 (20A) (audio unit hot at all times)
    • 22 (7.5A) (audio unit hot in START)
  • Battery junction box (BJB) fuse(s):
    • 20 (20A) (LH audio amplifier) (THX®)
    • 21 (20A) (RH audio amplifier) (THX®)
  • Circuitry
  • Digital signal processing (DSP) module (THX®)
  • Subwoofer amplifier (Audiophile)
  • Audio amplifier(s) (THX®)
  • Audio unit
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the audio unit, Go To Pinpoint Test A .
    • NOTE: Do not press any buttons on the audio unit while the audio unit is carrying out the self-test. System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the audio unit.
  1. If the DTCs retrieved are related to the concern, go to Audio Unit Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, and the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the key OFF or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has the following functions available:
    • Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
      • Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
    • Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
      • Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
      • While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs.
    • Preset button 3 = Signal Strength Test. This button displays the signal strength.
    • Preset button 4 = Software Version Display. This button displays the audio unit software version.
      • Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
    • Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then turns all segments off.
    • Preset button 6 = Configuration Status. This button enables audio unit configuration status.
      • Pressing the MENU button displays the ACM part number while in this menu.
  1. To exit the self-diagnostic mode, turn the audio unit off or turn the key OFF.
Feb 05, 2018 | Cars & Trucks
1997 ford f150 cruise control not working
I think you can use VDM UCANDAS WIFI Full System Automotive Diagnostic Tool or VAS 5054A. Both tools have different functions, VDM UCANDAS WIFI Full System Automotive Diagnostic Tool supports multi-models, including Australian Ford and Holden. It also supports wifi and online update. VDM UCANDAS works better than Autocom CDP.
http://www.careucar.com/wholesale/vdm-ucandas-wifi-full-system-automotive-diagnostic-tool.html
VAS 5054A best quality version, with OKI chip and bluetooth, support UDS protocols. This version vas 5054a support VW AUDI Bentley and Lamborghini, support multi-language.Now the newest version is V2.0.
http://www.careucar.com/wholesale/best-quality-vas-5054a-vw-audi-bentley-and-lamborghini-multi-language-diagnostic-tool-with-oki-chip-support-uds-protocol.html
You can go to choose according to your own needs
Aug 16, 2014 | Computer, Chip, Cruise Control for Ford...
Codes for samsung
*#06# - IMEI number
You can find more of these spread across the internet, and they're usually very handy to have, even if just to show off your geekiness to your social circle.
Mar 14, 2014 | Samsung Galaxy Cell Phones
HOW CAN I PRINT A TEST PAGE FOR MY KODAK ESP 5250
To print a test page:
  1. Make sure you have the latest version of firmware
2. Load8.5 x 11-in. plain inkjet paper in the paper tray. 3. Dothe following steps depending on the printer: ON ESP 3250, 5250, Office 6150 or 7250:
  1. On the control panel press Home.
  2. Select Maintenance, then press OK.
  3. Select Print Test Page, then press OK.
  4. Press Start.
  5. Wait for the test page to print.
For the 5000 Series Printers, a diagnostic sheet is usedinstead of a test page. To print a diagnostic sheet:
  1. Make sure you have the latest version of firmware. See How do I upgrade my all-in-one printer with the latest version of firmware?
  2. Load 8.5 x 11-in. plain inkjet paper in the paper tray.
  3. Do the following steps depending on the printer:
ON 5100: 1. Press and hold Quantity + Copy. ON 5300 or 5500: 1. Press the Menu button. 2. Scroll down to PrintDiagnostic Sheet. 3. Press OK. 4. Press Start. Wait for the test page to print.
Nov 20, 2010 | Kodak Office Equipment & Supplies
Rear parking sensors
does the version come equiped with rear park sensors????????
Does your vehicle have or could have parking aid ? Yes . Free wiring diagrams here
http://www.bbbind.com/free-tsb Enter vehicle info year , make , model an engine size . Under system click on interior & driver Amenity ,then under subsystem click on parking Aid . Click the search button then the blue link. The parking aid module is located behind right rear trim panel
Parking Aid Module CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
  1. Remove the RH interior trim. For additional information, refer to Section 501-01 .
  1. Remove the parts in the order indicated in the following illustration and table.
  1. Visually inspect the following for obvious signs of electrical damage.
    Visual Inspection Chart Electrical
    • Central junction box (CJB) fuse 26 (7.5A)
    • Circuitry
    • Parking aid sensors
    • Parking aid disable switch and LED
    • Parking aid speaker
    • Reversing lamps
  1. If the cause is not visusally evident, connect the diagnostic tool to the data link connector and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • SCP+, SCP-, UBP or ISP circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for parking aid module, Go To Pinpoint Test BC .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out self-test diagnostics for the parking aid module.
  1. If the DTCs retrieved are related to the concern, go to the Parking Aid Module Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart to continue diagnostics
Feb 18, 2018 | 2003 Ford Explorer
Printronix LineJet® P7210 Printer Logo
65 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
