Question about Adcom GFA-5500 2-Channel Amplifier
Distortion alert on left clannel when volume is raised,left speaker sounds like s#!t!(like interference)...
  • Scott Frye
    Scott Frye Apr 05, 2011
    Try switching speakers . If the problem "follows" the spkr then the spkr is bad.\
    If not then there's a fault in THAT channel...and what are you using for a source?
Ue boom connected to pc but is not playing music... if i get lucky i get muffled sounds play back, how do i fix this
Q: What should I do if the audio is distorted or drops out on my UE BOOM?
A: Audio distorted or dropping out when streaming to UE BOOM
If you're having trouble with audio distortion or drop-outs on your UE BOOM, try these suggestions:
  • Move the audio source closer - it might be out of the range of your speaker.
  • Move away from other sources of wireless signal - you could be experiencing interference.
  • Make sure your speaker has enough battery power (connect it to a power source with the supplied adapter).
  • Adjust the volume on both the audio source and your speaker.
  • Restart both your speaker and the audio source.
  • Re-pair your device with your speaker (see, "How do I pair additional Bluetooth® devices with my speaker?").
  • If you're using two UE BOOM speakers (for Double Up), try disconnecting and streaming to one speaker only.
NOTE: If you're streaming audio content from the internet, the issue could be with the internet connection and not your speaker.
Dec 26, 2014 | Microsoft Computers & Internet
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
Hi I have Samsung B2100 mobile phone. When I receive a message, the sound is so loud. Can you please tell me how to control the volume.
menu/settings/phone profiles, select profile, then choose options at the low left corner of display. Here, you can adjust type of sounds you want and its loudness. Navigate to the right with your central button and here you are navigating downwards: 1. - message alert type chooser, 2. - message alert tone, 3. - message alert repetition, 4. - email alert type, 5. - email alert tone, email alert repetition, and finaly, 6. - alert tone volume. To enter into the submenu, first click direct the central button, and then choose the volume with left or right part of your central button. I am not a perfect english speaker, therefore I hope I was clear enough making this explanation.
Dec 15, 2010 | Samsung B2100 Cell Phone
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
Have in built sound card in D845HV mother board. Experiencing heavy distortion as soon as the mic is connected. It was working well till last month.
Distorted or scratchy sound can be caused by several problems. Improving the sound can be as simple as rearranging your hardware components. The following suggestions may resolve the problem of scratchy sound:
  • Are there any other devices around the speakers or wires for the speakers? Electro-magnetic interference can cause poor audio. Try moving your speakers and wires around and away from other devices.
  • Have you recently added any new cards to your computer? Cards within the computer can also cause electro-magnetic interference. Try moving the card to another location within the computer, if possible.
  • Verify that you are not encountering a hardware issue with the speakers you have by trying another pair of computer speakers.
  • Poor audio quality or low volumes may occur if you are using passive (non-amplified) speakers.
  • Are your speakers too close to your monitor? The speakers can pick up electrical noise from your monitor so move them farther away. Subwoofers should never be placed near the monitor because their powerful magnets can interfere with the picture. They should be on the floor to maximize low-frequency transmission.
  • Are you experiencing sound problems only with particular games or programs? If you notice sound problems such as stuttering voices and static on some games or programs but not others, check with the software vendor for a software patch.
Data courtesy of: http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm
Also make sure to inspect your microphone, and the cord that connects it to your PC, for physical damage.
If you're still experiencing issues, you may need to replace the your microphone.
I hope this helps.
Ben P.
Apr 11, 2009 | Computers & Internet
NO Incoming alert/sound on my HTC Touch WM 6.1
In the left side of you htc, it's a sliding button. slide it to the top. this button is used to raise the volume.
Hope this helped!!
Dec 30, 2008 | HTC Touch P3450 Smartphone
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
Z-2300 noisy speaker
ur speaker is bad probebly torn membrane try replacing it (or disconnecting) this speaker there is a special kind of glue for membranes .... try it good luck windman
Oct 26, 2005 | Logitech Z-2300 Computer Speakers
Adcom GFA-5500 2-Channel Amplifier Logo
94 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
