Problem could be in the Ballast board it is what powers Lamp on, Encompass Parts Distribution 1-800-638-3328 they have them for 61.23 Part number BP47-00037A . You can Look up your Model # on their website.Problem could be in the Ballast board it is what powers Lamp on,
You can't post conmments that contain an email address.
2 possibilities. First, the bulb which allows you to view your picture could be burned out. If that is the case, your tv will turn on and you will hear audio but no picture. $85 for a new warranted bulb from Shopjimmy.com. Second possibility. If your TV is on with no picture or sound, you probably have a light engine problem.$325. I don't think it's your light engine. Just don't have enough information. Check the first possibility first. The bulb takes less than 5 minutes to replace. Don't buy just the bulb, buy it with the housing. It doesn't cost more, it costs less and saves a ton of aggravation. Don't touch the bulb with your fingers, use latex gloves when working on electronics.
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is. no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
HL T4675S
HL T4675S is the model of my tv
