Question about Sony CFD G505 Boombox
My Sony CFD G505 sometimes pauses for a few seconds while playing CDs in a room for a group of line dancers. It doesn't do that at home. There is usually a band present, setting up instruments. I tried setting up on the opposite side of the room from the band, but that didn't work. Could this be some type of interference, and, if so, is there a way to prevent it.
  • wherron34 Apr 01, 2011
    This is a fairly new instrument that has been cleaned regularly. The problem has not occurred at home. I rehearse with selected CD's at home before going to the senior center. At the senior center, I play the same CDs for a group of line dancers. Following the line dancing, there is a live band which plays for ballroom dancing. The band usually arrives during the line dancing. The problem seems to occur while the band is setting up and testing their equipment. We have been sharing
    electrical outlets. Moving across the ballroom from the band did not solve the problem.
    Genius:
  • 1,622 Answers
Hello .should the laser be weak and not just dusty a repair would be impractical as our labor is 90$ before the part cost.. from the picture it looks like a top loader in which case you could manually clean the laser with a simple q-tip---gently in a circle clean the lens dry q-tip no liquid .. also does it fail with different discs? if only with one that disc might be scratched ,dirty etc..
Posted on Mar 31, 2011
Is a replacement antenna an easy fix for ordinary person (Sony cfd-10 boombox)?
All antennas are the easiest repair an non-electronics technician can try to do
Oct 07, 2013 | Sony CFD G505 Boombox
Where can i fine antenna replacement for sony xplod cfd-g505
Go on line to the SONY website and request the parts list for your boombox. THen order it!
Jan 01, 2013 | Sony CFD G505 Boombox
This problem is with my home theater HT-TZ512. The disc sometimes loads, plays for 15-30 minutes, then randomly stops. The picture is still on screen. It looks like I pressed the pause button. When I...
You need to try a DVD Laser Lens Cleaning Disc.
If this doesn't work then you'll need to remove the cover and clean the Laser Lens with some Lens Cleaning Fluid and a QTip. Just use a few drops on the QTip and then wipe over again with a dry one.
If the above fails then its the Laser that's failing which isn't normally cost effective to replace.
A good way to check is if it will still play CDs but not DVDs then its the Laser.
Jun 11, 2011 | Samsung HT-TZ512T Theater System with...
An electrical surge fried my CFD-676 with CDs in the reader. How can I get the CDs out of the box?
There should be a small tiny round hole on the front. Get a paper clip and straighten it out then push it through the hole until you feel the door open.
Oct 25, 2010 | Sony CFD-646 Boombox
Sony CFD G505 CD Radio Cassette-Corder - I have no power when power button is pressed. It is 6 months old. Could it be a fuse from a power surge. It was pluged in at an older trailer house. The lights do...
If it is only 6 months old I would recommend you take it back to where you bought it as it is still under warrenty. If you start playing with it and take it apart the warrenty will be void. But dont tell them about the old trailer house bit, just it stopped working.
Jul 25, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
My CFD-Z501 won't play a disc. I get the message "no disc"
Try to use CD/DVD clening disk ($6 in Walmart). Or simply use cotton swab (Q-TIP) and 40 % ethyl alcohol (vodka) or 50-70% isopropyl alcohol (NO ACETONE), depending on your budget.
Also check if discs are inserted correctly and not damaged/durty etc. Also check your discs. Some CD-players dont accept burned CDs (copyed). I believe Sony is not the case, just a suggestion.
If cleaning wont help lens might be damaged.
Good Luck
Jan 26, 2009 | Sony CFD-Z501 Boombox
Sony CFD G505 Boombox Logo
89 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
