Heating & Cooling Logo
Posted on Mar 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THE FAN ON MY AIR CONDITIONER EXTERNAL UNIT HAS BROKEN AND I AM LOOKING FOR A REPLACEMENT FAN
Anonymous
Level 2:
Scholar:
  • Expert 133 Answers
  • Posted on Mar 31, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
133
Questions
0
Helped
29153
Points
308
Grainger is a common and reasonable supplier who will sell to the public. Take the old one with you for them to match.
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Broken fan in unit, bought replacement fan. need to know how to replace
Use Bing or Google and search for videos that show how to fix it yourself...sometimes you might watch a dozen different videos till you find one that is easy and very helpful...but keep searching, there are videos out there for everything.
Is the fan on the outside unit supposed to turn when the heat is on or only for the air conditioner? Our unit is omitting a strange odor and the fan will not move even if we switch the unit to air...
The outside fan is used when ever the compresser needs to be cooled. So depending upon the outside temp as well as the temp of the refrigeration, it may not come on. When you say "our unit is ommiting a strange odor" are you refering to the outside condenser? or from the air handler? and what does it smell like? Please give us more to work with to be able to help you. Yes there are people looking and working on problems here at Fixya.com.
The tube on the external bucket going to the unit is broken where can i buy a replacement part
use this model number for a whirlpool 10,000 btu portable ac
ACP102PR0 a very similar unit.
great online parts outlets:
appliancepartspros
repairclinic
sears parts or
pcapplianceparts
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Fedders A3X06F2G window air conditioner fan does not spin
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
Condenser fan mounting
Most condenser fan turn ccw looking down into the unit and should be mounted about 1" from motor. A good check is that the air is moving up and out and drawing through the condenser. Thanks
Top Heating & Cooling Experts
Paul Carew
john h
