Question about NEC ND-3550A-KIT DVD±RW Burner
Nec nd-3550a won't recognize dvd discs. will see and play cd discs. Have checked all registry entries mentioned on multiple web sites. Tried to take it apart to clean the lens. Got the bottom off but could go no further. won;t see my dvd cleaner disc.
  • NEC Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
Posted on Mar 31, 2011
Just looking for latest driver for nec dvd rw nd 3550a. been on a number of sites and all just offer driver bots to search, all i want is this one driver to get my dvd working again? is there a site i can...
try this your original drivers may be in conflict with your antivirus program in your registory this is a microsoft patch use the xp version even if you run vista as it doesnt work
http://support.microsoft.com/kb/314060
Oct 16, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
I have nec dvd_rw nd-3520a on my computer it will not play dvd ram is there something i can download to facilitate this?
fraid not , these are the only dvd formats this drive supports
DVD-ROM • DVD-Video • Multi-Session • DVD-9 • DVD+R • DVD-R • DVD+RW • DVD-RW
dont try to flash the drive
Oct 07, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
No upper and lower filters visible in registry
boot your computer into the bios and check to see if the drive shows there , if it does then dissconected the drive ( with power off ) and reboot the computer , let it fully boot , then turn off and reconnect the drive and windows should pick it up
Oct 02, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
My desktop is not playing cd or dvd's.
go to control panel and search for new hardware...or download new firmware fpr your device
Sep 29, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
My nec 3550a wont pickup a burnt dual layer disc
It may not be compatible with a dual layer disk, just the regular dvd-r or dvd-rw disks.
Jul 19, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
Have NEC 3550A DVD/rw. re-installed windows XP professional & all else.. DVD will not recognize most dvd discs.Got drivers from NEC.. still problem
Go to:
1. start > run > devmgmt.msc
2. Under DVD/CD Rom drives make sure it's installed (Uninstalled = Yellow icon)
If all drivers are applied correctly this could be a problem with the DVD Region Settings.
Go to:
2. expand
3. find the device
4. right click > properties
5. go to dvd region tab
6. select the desired region
Warning: some drives only allow you to change it up to 5 or 4 times so be careful!
Jun 23, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
I have problems with my nec nd-3550A dvd rw
Make sure that your buner supports the type of blank DVD that you are using.
Jan 24, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
NEC ND-3550A won't read discs
I found out that whenever I put my computer to sleep in S3 mode, after waking up, NEC wouldn't start (even after firmware update to 1.07). Problem can be overrided either by turning S3 off (put it to default S1) or by disabling and reenabling NEC DVD. This may help for some other problems also that are connected to kikoksky proposed solution (which btw didn't solve problem for me).
I created MS-DOS Batch file (.bat) with Microsoft's DevCon tool for this action:
cd "C:\Program Files\DevCon\i386"
devcon disable "IDE\CDROM_NEC_DVD_RW_ND-3550A____________________1.07____"
devcon enable "IDE\CDROM_NEC_DVD_RW_ND-3550A____________________1.07____"
Jul 23, 2008 | NEC ND-3550A DVD RW Dual Layer Burner
Can't read dvd
club.cdfreaks.com firmware update
Mar 16, 2008 | NEC ND-3550A-KIT DVD±RW Burner
DVD Drive Problem
one easy test to do is use a bootable cd and boot from cd instead of windows. if it boots its an issue in windows. if it don't boot its likely bad hardware.. i have exact same model drive for over a year
a good boot cd easy to get is a memory tester www.memtest.org the zip file has an iso i burn with imgburn.com tool
Nov 03, 2007 | NEC ND-3550A-KIT DVD±RW Burner
NEC ND-3550A-KIT DVD±RW Burner Logo
239 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
