Question about Husqvarna Models 61-66, 266, 268, 272
My Husqvarna 272 K saw will not get the rpms it should. Only time it opens up as it should is right before it runs out of fuel. Clean fuel, filter, fuel line, etc. It will cut but not like it should. It starts fine, idles good, just won't open up. This is a metal cutting saw but assume you know this and don't see that being a factor. Any suggestions would be appreciated.
  • 710 Answers
Hi Mike,
Sounds like your carb needs to be leaned out a bit. Are you closing your choke all the way after it warms up?
Hope this helps,
If it does, please place a vote or comment for me. Thanks,
Handie Andie
Posted on Mar 31, 2011
Husqvarna k750 sawing stone starts up fine filters clean stawls under load
Start by changing the fuel filter in the fuel tank, if this does not help remove the top covers and check the impulse pipe to the carb has not become diss connected, let me know if it still is not right.
Apr 10, 2011 | Husqvarna Garden
Husqvarna 55 Chainsaw (1999) - Runs OK for 1 minute then stalls
I think your on the right track
Blowing compressed air through your tank vent
is great but it is way more air than the natural asperation
that the saw pulls on it own
I would replace the vent cap and also look for a pinched fuel line between the fuel tank and the carb
Apr 07, 2010 | Husqvarna Chain Saw 20" Bar
Have plenty of compresssion , are getting fire , seems to be gettin g fuel but still will not start - 570 husqvarna
If as you say it has good compression, spark, and fuel, yet will not start, it is most likely flooded.
Model 570 IPL (may not be your saw)
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901006.pdf
Detail G (Muffler) clean Item 3 and try once more.
Remove the plug (wet?). Install a new plug (very inexpensive).
Download your manual and follow the start procedure exactly.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL/Manual
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
My 359 floods in a nano second if I leave the choke engaged once it attempts to start. The only other time it really gave me trouble was one time I failed to set then turn off the choke when it was warm. Setting the choke also sets the fast idle on my saw. Once it has fired pulling the starter with choke on floods it.
If it still does not at least try to start, remove and clean the air filter. Put about a teaspoon of fuel mix in the carburetor throat, reinstall the clean air filter, turn on the ignition, close then open the choke, set the fast idle (if equipped), and try to start it. Did it sputter? If it sputters, attempts to run and quits it probably has a fuel delivery problem.
At this point I think it time to contact a local chainsaw seller mechanic (I use Stihl). For about a tune up/repair estimate. $40 - 60 depending on parts required. If tuned by local shop when you pick it up ask what fuel/oil mix they used (should be 50:1) and use that mix until the next time it needs service (I suggest you affix a self adhering tag near the fuel cap). HTH
Lou
Nov 23, 2009 | Husqvarna Chain Saw 20" Bar
I have the same problem as this guy.
DARN! I can't post the link as a clarification. Go to SmallEng.com; you'll find these under "Free Repair Videos" The thread you reference is closed so my guess is it worked. Again GL
Lou
Sep 20, 2009 | Husqvarna Chain Saw 20" Bar
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna chain saw that runs great when it is flat but when you turn it side ways to notch cut it sputters and dies the low high and idle screws all seem to be adjusted right and it has a new...
If the fuel filter was recently replaced the hose inside the fuel tank is almost certainly free to move when the saw is tipped (filter on free end of hose). There is a slim possibility the hose has a hole that is immersed in fuel when the saw is in the normal position and open to the air once the saw is tipped causing starvation. I think this problem is beyond the capability of most users to trouble shoot and repair. Please try your neighbor chainsaw shop for repair. HTH
Lou
Sep 09, 2009 | Husqvarna Garden
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Jan 05, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna Models 61-66, 266, 268, 272 Logo
167 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
