Question about Gsi Outdoors X-Box 360 Replacement Battery 2100mAh
If your dvd is dirty what can i use to clean it
Alba tv dvd combi problem
Picture noise / distortion
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
  3. Try a direct connection from the DVD player to the TV set, instead of via other components.
    Test the wires connector terminal from dirty and corrosion, clean it with contacts cleaner very well and try again.Use the Disk cleaner for clean the Pickup system
    God bless you
Feb 09, 2013 | Televison & Video
It does not read cd's or dvd's when inserted in the tray?
Hi..
this may caused by
  • Dirty Lens
  • Faulty Internal Mechanisms
  • Corrupted Data transfer
  • Dirty Lens- Your Drive's Lens may have become dirty and you need to clean the lens.It is usual that the lens become dirty time to time. You can clean the lens by the cleaning Disc which can be purchased separately from a nearby computer shop.
  • Faulty Internal Mechanisms - all internal movements are powered by a small electrical motors and belts. If any of these are not working as it would, then Drive may not work as expected. You may need a expert hands to clear this problem.
  • Corrupted Data Transfer - If all the internal parts are working properly but data cable is not connected properly, then too drive may not read any discs. you can reconnect the cables.
Mar 23, 2011 | Pioneer DVR-107D DVD±RW Burner
When attempting to record on a new blank dvd (-R), I receive an error code c1300 for a dirty disc. I have cleaned several discs and all stop after a minute or so, followed by the message dirty disc with...
the burn laser is dirty clean it using a laser disc cleaner avaliable from all good electronics shops that sell tv and audio decks hers a picture of what they look like
Dec 28, 2010 | Sony RDR-GX300 DVD Recorder
When i insert a dvd it loads then shows wrong disc. Does this mean the laser needs to be cleaned?
hello,
when your player shows wrong disc, it is either the laser is weak or dirty.
if it is weak, it needs replacement.
if it is dirty, its just cleaning that is needed.
take care
Jun 08, 2010 | Prosonic PD-007 DVD Player
The dvd doesn't work when on play ,
Most likely cause, dirty lens on laser. Quick fix: buy and run Cleaning CD ( Radio Shack etc ). Don't use a DVD cleaning disk as these often will not start up when the lens is dirty.
Nov 30, 2009 | Disney DTD1363-CAR 13" TV/DVD
Dvd drive keeps faultering solve this
Most likely, the DVD laser sensor is dirty.
1. Use a can of compressed air ($6) to maybe clean it enough to work.
2. Obtain a DVD drive cleaner kit from Radio Shack (maybe WalMart) ($12).. it is a disc that has a tiny brush on it.
3. You have to "play" the CD/DVD through "track 04" - Read instructions carefully.
This will work.
It could also be dirty DVD discs (not likely)
1. Clean the DVD disc with a lens cleaner wipe (like for eyeglasses)
2. or clean your hands when eating pizza and watching a DVD movie.
Hope this helps!
Sep 04, 2009 | Computers & Internet
Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Feb 08, 2009 | Samsung BD-P1400 Blu-Ray Player
Dvd sticks while playing. What to do ? Emerson dvd/vhs player
hi connie steed,i see there is a problem with the dvd you are playing is dirty or scratched if not the your dvd player got a dirty lens.clean it with a lens cleaning disk u will get in your local market.have a nice time.
raj..
May 12, 2008 | Emerson EWD2203 DVD Player/VCR
Gsi Outdoors X-Box 360 Replacement Battery 2100mAh Logo
12 people viewed this question
Top Gsi Outdoors Video Game Consoles & Games Experts
James Wishart
Are you a Gsi Outdoors Video Game Console and Game Expert? Answer questions, earn points and help others
