Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
I have a ssr ep-15 compressor. It turns on but does not cycle to high pressure. It doesn't seem to have any leaks. all the contactors pull in . pressure switch works. can something be wrong with the intake valve?
  • 2 more comments
  • Samuel Charles Spriggs Mar 31, 2011
    How old is it ? How many hours has it run ?
    Charlie
  • atthomp Mar 31, 2011
    9 yrs old. about 38,000 hours on it
  • atthomp Apr 01, 2011
    this is a rotary screw compressor - no pistons
    no I don't believe it is. In the oil tank their is a air/oil seperator, and it mists oil into the recip. screw.
    President:
  • 1,489 Answers
I would say it's the piston ring(s) or vlave(s) or both leaking by -- in that case it would need a rebuild.
Charlie
Posted on Mar 31, 2011
  • 2 more comments
    This is a rotary screw compressor no pistons.
  • Samuel Charles Spriggs Apr 01, 2011
    Is it the oil-flooded type ?
    Charlie
  • Samuel Charles Spriggs Apr 02, 2011
    I think it may be the "oil-flooded" type rotary screw compressor -- the screws are misted with oil for sealing & cooling -- in that event, I doubt the screws are worn or the compressor is leaking by.
    So, I would say you could be correct that it is a problem with intake. Viewing the schematic, there is a filter on the intake which could be restricting the air intake, but I assume you have checked that. Given the filter is not clogged, the next suspect would be the valve itself.
    I would suggest cleaning the intake valve, it may be sticking. It's probably best to remove the valve to clean it -- WD-40 would be a good choice for cleaning, but it'd be a good idea to not have the valve dripping with it when you try the compressor again -- removing it to clean would allow you to minimize the amount of WD-40 getting into the system.
    That's my best guess at the moment -- which is pretty much the same as yours.
    Please let me know if you try this and how it works.
    Charlie
  • Samuel Charles Spriggs Apr 06, 2011
    Thanks fpr the rating -- I appreciate it !
    Charlie
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a Ingersoll rand
Start with the simple things first... had a fellow a couple of montha ago that did not realize that there is an air filter....cleaned that and the air compressor worked great a again....
So... check your air filter...
Also does that model have oil in the crankcase??? is so check that you are part way up in the site glass with oil...if the unit has been used heavily, has the oil every been drained and changed???
This could contribute to rings getting sticky and hanging up...
If none of these things work then start going deeper into things...
heatman101
Goldair2 180ah airconditioner not cooling.gas still full.how to check compressor?
Johan, there is no way to determine if the 'gas is still full' if the compressor is not running.....so it could be locked off on a low pressure switch because all the 'gas' is already leaked out.
If the contactor is pulled in when the thermostat calls for cooling, but the compressor does not run check for full voltage on the incoming side of the contactor as well as on the outgoing side of the contactor. If its going in and not coming out, the contactor is bad. If is coming out and the compressor is not running, look for a burnt wire first on the contactor then on the compresor dome. Look too for a burnt wire on the capacitor on the terminals marked 'C' and 'Herm'. Check to see if the capacitor is expanded or swollen up. If it is, it is shorted or open internally and allowing the compressor to overheat.
You probably need to call a competent repairman unless you are comfortable working with high voltage and capable of understanding basic wiring principles and able to follow the wiring diagrams to determine where the fault is.
Safety is no accident. You will be exposed to dangerous wire connections and should only trouble shoot with the power on IF you are competent around electricity.
Oct 04, 2015 | Heating & Cooling
Why does the compressor on my goodman package unit turn on and off before completing a cycle?
There is several possible causes. The most probable cause is wrong charge. Many units have a low suction safety on the low pressure side of the compressor. There is often a high pressure swithch to guard against over pressure also on the high pressure side. If your unit has the condensing fan stop in mid cycle, the compressor has inherent motor contacts inside the compressor to help guard the compressor from overheating. I just recently had to replace several customers main contactor because the contactor contacts were severly burned and sometimes could pass current and sometimes could not. I also had a few customers whose condensing unit was so dirty that the compressor was overheating causing the inherent motor contacts to open. Hope this gives you some ideas to look.
Sep 02, 2014 | Goodman Heating & Cooling
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Carrier puron 38txa a/c compressor will not turn on
Make sure there is power at the compressor, but first at the contactor (being supplied to contactor ). Power being supplied to contacter (line voltage) ?
Yes, then close contactor manually and if it works then check for 24 volts at the contactor coil. Find 24 volts, then you need a contactor.
No supply (line voltage), then check breaker
Breaker on, then check run capacitor and if good check high and low pressure protection.High pressure = trips on high head pressure (manual reset) then clean condenser coil.
Low pressure trips on low charge (auto reset on restored charge)
Sep 03, 2013 | Heating & Cooling
Outside unit starts but stops running in a few minutes. The rest of the a/c seems to be fine but doesn't cool
there could be quite a few problems with it. either it has something to do with the high or low safety pressure switches. Or you have a low voltage issue-not getting enough low voltage power to the coil of the contactor. how long do you wait after you turn the unit on? there is a 5 to 10 minute delay in the control board to keep the compressor from short cycling. meaning to keep the compressor from turning off then on again right away. short cycling a compressor too much will ruin it. There also could be an issue with the delay board it self. Or its a heat pump it could be an issue with the defrost board or the defrost sensor. I have even seen it to have a short in the wires of the coil of the contactor. But when that happens it will burn out the transformer or the low voltage fuse of the transformer or on the control board.
have you got it figured out already? If not can you give me more info on what it does? Or if it ever comes on after you wait at least ten minutes. Can you hear the hum the coil of the contactor makes when it is calling for the cooling. you might even have a problem with the contacts of the contactor not getting the proper power thru it to turn or keep the unit on.
Like I said there could be quite a few different possible issues with it to not stay on.
Apr 13, 2013 | American Standard WCZ036F Air Conditioner
I have a SSR-EP60 air compressor and am having a problem with it unloading. It would shut off for high pressure (145). I changed the air piston to the intake butterfly and seems to be a little better. I...
If the pressure continues to rise, the inlet valve is not closing completely. Remove the top of the air cleaner box and look down at the inlet valve butterfly. When the compressor is down or unloaded, the valve should be held closed by an internal spring in the air cylinder. If it's not, the mounting stud on the bracket may have come loose and moved, or more likely the spring in the air cylinder actuator is broken.
This actuator has gone thru at least 3 revisions. I just replaced the cylinder on our EP60 because the spring had broken in two places and wouldn't come anywhere near closing the valve.
May 26, 2011 | Ingersoll Rand Stationary Air Cooled...
Danby DAC7003 cycling
Could be a freeze protection (low pressure) switch, high pressure switch or the compressor could be cycling on internal overloads.
Jul 09, 2010 | Danby Heating & Cooling
Unit will not come on at all has voltage to unit and to contactor?
Sounds like you lost the refrigerant charge. Low pressure switch will not let compressor run. Look for oil around the condenser tubes. If you find it, this is probably the leak source.
Jun 01, 2009 | Heating & Cooling
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
396 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
