Question about Water Heaters
Steam Mist Generator: SM7-IM or(1M) Conductor: TC150 Goes on by itself. Had to shut off breaker
    Scholar:
  • 133 Answers
Not sure on this model but most are turned on by sensing water pressure when the faucet is turned on. Any leaks in the faucet washer or seat?
Posted on Mar 31, 2011
Hot water heater continually heats water, popping noise and steam from front of unit. Why
This is a serious problem. Safety and water damage are serious concerns.
If this is an electric shut the breaker off. If it is gas turn the temperature to off and close the gas valve. This is very important to your safety.
Check for water leakage and protect the floor from water damage. It is likely leaking.
Check your warranty and call a qualified repair service.
Sorry for the bad news!!
Hope this has helped?
Mar 24, 2016 | Rheem Water Heaters
On a laurastar s4 water leaking from tank now the greenlight wont come on
the fault is with the PCB card which sits underneath the water tank, so any leak from the top could end up on the card causing to short. you can contact us on 0208 4419412 and we will help you. we are an electrical repair centre in Barnet specialising in repairing high end steam generators like yours
Air Purifiers Conditioners Humidifiers Steam Generators Steam Cleaners...
Feb 18, 2013 | Water Heaters
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
Jun 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
My Lian tankless electric water heater has shut
there could be a ground fault recepticle between panel and unit.[might be tripped] or there mustbe reset on unit. no led on unit usually means no power.
Dec 02, 2009 | Water Heaters
Blinking red light no heat
It sounds like you are actually in lock out. Recycle is when during a call for heat, the flame goes out, the unit will try to restart itself. Hope this helps
Nov 10, 2009 | Water Heaters
My paloma tankless water heater shuts of but the display goes blank and does not show an error code.
check to make sure circuit breaker is big enough to handle your unit if not get correct size
Oct 07, 2009 | Rheem Paloma PH-28R IFSN / RTG-74PVN...
Wilo 3speed recirt pump for my wood stove
I wasn't aware that you would put a citculating pump on a tankless water heater, but as long as the arrow goes in the direction of the water flow that is how it needs to be,, putting a circulator on a tankless kind of goes against what it is for, the tankless will never shut off and once it is on how will it ever satisfy itself to shut down?
May 26, 2009 | Grundfos RCP-96 Recirculation Pump for...
I have to reset the breaker to make the water come on
You definitely have an electrical short in either your water heater or the circuit breaker itself. I would begin by testing the breaker. If you do not have the equipment necessary to check these items call in a pro.
May 17, 2009 | Water Heaters
Home heating, boiler shutting down
Is this appliance a gas fired or oil fired. Steam or hot water
Jan 09, 2009 | Water Heaters
Radiator Leak rust
what part is leaking ?what type of set up do you have? steam or water
make sure you completely drained and refill the system before use. your water level needs to be corrected or this will force water up the lines instead of steam
your radiators need to be pitched so that the steam (water) can return back when the system shuts off
as for the leak. where it is or what part is leaking
heres a manual for your system
http://www.ariston.co.uk/uploads/doc4947b0d538f79.pdf
hope this helps
Dec 24, 2008 | Water Heaters
Water Heaters Logo
62 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
