Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door pad
I just purchased the house and the old owner dont gave me the manual for the garage. I want to set a new code for the pad that is located outside the garage door but i dont know how to the the manual. is a craftman sears and i looked inside the keypad and the number is 031D0359 thanks
  • lolo-retta Aug 07, 2008
    sears craftsman garage door wireless key pad
  • geremepullin Aug 10, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
You need to press and release the learn botton (don't hold it or you will clear all the codes)
If the light bulb(s) on your operator are on the front and/or back, the learn botton is on the back of the operator. If the lights are on the sides of the operator then the learn botton is on the right side (looking from the back of the operator and facing the garage door).
After you press the learn button you have about 30 seconds to press in the new 4 digit code in your key pad then hold the enter button until the light on the operator blinks (about 2 seconds). If this does not work check the battery and try it again.
Posted on Feb 07, 2009
Keyless pad will not communicate with reseiver
Are you sure you purchased the right keypad? The model you should have is 139.53681
May 03, 2012 | Sears Craftsman LiftMaster Chamberlain...
Batteries need changing in the garage door remote control. It requires the code to be reset but the previous owners of the house left no information. It is a Wayne Dalton, Magic Touch, Model Number...
Using a step stool reah up and remove the plastic light cover from the garage door opener and the the code setting instructions are written on its panel. Or seach on LiftMaster.com for help.
Jul 26, 2011 | liftmaster Remote Light Control Garage...
Bought house with craftsman garage opener. Owner only had one remote. Bought a new remote at Sears that matched color code. followed instructions to code remote...that worked but made the old remote non...
Post the model number of the opener and the model numbers of the remotes. The opener model number is found on the end closest to the door and starts with 139.
Try programming the keypad like this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
After programming the keypad see if either remote will work with it. Post this information also.
Oct 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
Jul 24, 2009 | Chamberlain 950CB Remote Control
My garage door opener only works from a couple feet away
On the rear of your motor unit just to the left of all those white wires you will see a small light. If this light is flashing randomly it is normal. If it is flashing rapidly it is an indication of interference or you have keyed your remote. It really sounds like interference and you will have to do some more checking things.
315 mhz is the radio frequency and you cannot change that. In fact if you purchase a new opener you will get that same frequency.
Your opener was made by Chamberlain Mfg. Co. that also makes Liftmaster. That may be where the confusion comes in.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Setting garage door opener
Most openers are programmed the same. You normally program the house garage opener to accept the new remote. Your garage opener will have a button to press to add in a new remote. Normally you press this and then press the remote in the car and hold until your lights on your opener flash or the garage door closes. (check your manual on your garage door opener)
Mar 27, 2009 | 2005 Chevrolet TrailBlazer
Need pin number
Try going here and clicking on your specific model. Each models page has instructions included.
http://www.aclickawayremotes.com/Liftmaster/help.html
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changing code on keyless pad on old garage door opener
NOT FAMILIAR WITH CRAFTSMAN MODEL NUMBERS
IF THE UNIT HAS SAFETY EYES YOU SHOULD BE ABLE TO FIND A SQUARE PROGRMING BUTTON.
PRESS AND RELEASE YOU NOW HAVE 20 SECONDS TO INPUT THE NEW CODE ON THE KEYPAD AND PRESS ENTER.
HOPE THIS HELPS
Sep 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,235 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
