My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
  • Anonymous Mar 30, 2014
    the machine is not washing it comes up with codes like HC or LL
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Posted on Jul 27, 2011
WHAT is causing my Westinghouse Top Loader Washing Machine model LT809S to only agitate in one direction ??
problem with the direction control relay or power board
call a technician to diagnose properly
Jul 21, 2015 | Westinghouse Washing Machines
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
Showing LL error code
This error code means LARGE LOAD and shows thatthe machine is overladed with washing. Remove some and reset the machine and all should be well. If the fault persists then the following will need to be checked:
Sep 08, 2012 | Washing Machines
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
Getting a beeping signal with a code message PF
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jan 24, 2011 | Kenmore 46472 Front Load Washer
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Beeping flashing "H" and "F" wont wash
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My westinghouse lt809s is very noisy while spinning. The part under the agitator looks 'corroded' and probably needs to be replaced. Suggestions?
Then you probably either need to clean that bearing assembly up or go to an appliance parts center and take the model number with you and purchase a new bearing and pulley assembley.. Also check for worn belt.
Mar 12, 2010 | Washing Machines
Maytag Neptune FAV6800AW Code LL Machine displays code LL and will not complete the spin cycle when there is something in the basket. Will complete if empty. Thinking the issue is the tub displacement...
Hey HopelessR,
The LL error code For the FAV6800AW is one of those errors that I feel is not documented very well. The only explanations I see is Large Load detected, “” The washer cannot spin because the load is to large”” OK what the heck is the trigger input to the Control Board to issue this error code to the Console Display????
I believe it’s Motor RPM not reached. I would try the Quick Spin Test on page 14 of the Service Manual and see if your machine will spin up to 850 RPM with an empty wash basket. Do you run up to 850 RPM “85.”?
I then reran the test with two large bath towels that were soaked, had to lay them in the wash basket to balance as best I could. I wanted to rerun the test with some load. The wash basket spun up thru all ranges to 850 RPM and completed with 3 beeps. Just wondering what RPM range you can complete too.
I have to additional commenst, this board has message limits for guys like me.
Oct 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
