Question about Refrigerators
The compressor just died i took a look at it and noticed a little black box attached to the compressor was kind of melted so i cheked it out and it defenatly smelled like burned wires
  • Samuel Charles Spriggs Mar 31, 2011
    This is probably the relay and / or start capacitor. Sounds like replacing this part would solve the problem. More info, let me know.
    Charlie
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 31, 2011
Breaker trips when you try to start compressor motor spins a little before tripping breaker
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
May 04, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Tip
GE ice box control board revamp
These new fangled GE ice boxes have auto defrost boards in them. The boards control the compressor, the fans, and the damper as well as the defrost functions. The program in the computer board uses a method to determine defrost such as how many times the door was opened and how long the compressor has been going (hours) and how long it took for the last defrost cycle. this is to insure even defrosting no matter what climate you live in. The board relies on inputs from sensors located in the freezer compartment and the fresh food compartment. It also relies on a sensor for defrost action a larger bulb mounted on the coil. If the bulb gets out of place it could compromise defrost operations. The board itself is easy to remove and cannot be screwed up wiring wise because all of the quick connects are different. The board itself is mounted on 4 plastic standoffs. On one of these boards I removed I noticed a burntspot on the back side of the board. It was the compressor relay that activates the compressor from the board. My opinion is today's lead-less solder does not hold up as well as older type lead soldier and therefore the heat from the relay melts the soldier. I took a cheap iron and re soldiered the connection the board and re installed it. The ice box has been working great every since for more on diagnosing GE ice boxes with auto defrost controls check out my web page
The page has service manual downloadable for late model GE refrigerators.
on Apr 06, 2011 | Refrigerators
Kenmore Model # 10654502300 side by side
yeah your relay is burt out by the sounds of that
your compressor may be the cause, or it could be that the relay has just had enough
May 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/freezer not working
remove the bottom panel on back of fridge. locate the compressor( round black object with copper tubing coming out of it. check where the wiring plugs into it and you will probably see a white plastic box attached to the compressor.this part can be pried off with a screwdriver and if it is white this is your problem. whirlpool had a defect in this relay and they go out quite frequently
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Fuseholder melted overdrawing amps and not heating amana hcd18sd
FUSEHOLDERS MELT ON MICROWAVES ALL THE TIME its the most common thing that makes the microwave die 99.9% of the time its nothing , something to do with the metal that is usedin the fuseholder , and the fuse .with a long run of the oven the fuse gets hot and the fuse melts inside . sometimes you can get away with a little contact cleaner on the holder and a new fuse . other times you will need a new fuseholder too. good luck
Jan 22, 2009 | Amana HDC21 Microwave Oven
Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
May 06, 2008 | Kenmore 73503 Stainless Steel Bottom...
Not cooling at all
NEEDS A RELAY IN COMPRESSOR,THEY GO OUT WITH A POWER SURGE,JUST MAKE SURE RELAY IN COMPRESSOR IS HOOKED UP CORRECTLY ,REMOVE COVER FROM BACK THERE IS A SMALL BOX ATTACH TO COMPRESSOR REPALCE
Jan 03, 2008 | Kenmore 55609 / 55602 / 55604 / 55606 Side...
I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling. It worked fine up until last night when we noticed that the ice was melting. Now it gets a little cool but not cool enough....
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Nov 04, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
