Question about Roper Dryers
Dryer not heating. check the thermostat, the heating coils and the fuse, all check out fine. What could be the issue?
  • Roper Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 31, 2011
4 Suggested Answers
  • 142 Answers
SOURCE: not heating up
check the wiring to the heating element and ensure all the connections are tight and there are no burned wires. The heating element should be continious with no breaks.
ohms should peg the meter if everything is good.
Posted on Jun 02, 2009
  • 32 Answers
SOURCE: whirlpool dryer model LER3624jq0 has no heat but
They could get electricity but when the coils are broken into the will not heat. Diaphram is at AppliancePartsPros.com I dont actually know them but I found my parts there.
Posted on Oct 10, 2009
heatman101
  • 43501 Answers
SOURCE: Electric dryer not heating. I
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on Jul 04, 2011
Our frigidaire gallery dryer won't heat up. It turns fine, and we have tried it on multiple settings.
Hi mommylein...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 17, 2011 | Frigidaire Electric Dryer
My Kenmore He4 electric dryer is not heating. It is running fine, but does not heat to dry the clothes. What do I need to do?
Hi tomsavaloja...
Check your Wiring
Sep 15, 2011 | Kenmore Elite HE4 Electric Dryer
My Maytag dryer is not heating up. It runs fine. Model PY2300AYW
Hi peaseg13...
Check your Wiring
Sep 09, 2011 | Maytag PYE2300AY Electric Dryer
It sounds about like many of the guests on this site (FixYa). My dryer runs and turns fine, but does not heat on any setting.
Hi joracheff...
Check your Wiring
Sep 05, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Dryer runs fine, but doesn't heat.
Hi jasonsimonso...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 01, 2011 | Dryers
Kenmore 90 Plus Dryer is not heating up
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | Whirlpool GGW9868K Gas Dryer
My Neptune dryer is not heating all the time it's running but stops heating after awhile
Hi
Thanks
Rylee
Jul 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Kenmore Elite HE3 gas dryer does not heat up? What do I do?
Hi
Thanks
Rylee
Jun 21, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating
if takes a long time then u have a venting issue.
if no heat first check your breaker a dryer willl run on 120volts but 240 is needed for heating..
if electric check ur heating element, thermostats, thermal fuse for continuity with a meter
if gas check the ignitor,thermal fuse, or gas secondary coils..
Feb 05, 2010 | Whirlpool Dryers
Kenmore Elite 110.7208201 won't heat up.
Hi
Please check the things that could stop a electric dryer from heating:
- House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
And also check the things that could stop a gas dryer from heating if you have a gas dryer:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dryers
Dryers Logo
37 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
