Question about Samsung Refrigerators
Hello, we hv the samsung SR-C31NMO samsung fridge. from 2 days the freezer is not working. Same thing had happened few days back, but automatically it became normal. I can hear some sound behind the freezer, but only for few mins.. pls let me know wht the problem is.. thank u
  • 132 Answers
It sounds like the evaporator fan is not working properly. If the fan is stopping and starting it can cause the freezer to become a block of ice.
The fan motor may need replacing
Posted on Apr 01, 2011
Samsung SR 61KTC fridge not cooling but freezer is fine fans seemed to be very noisy a few days ago now sound like not on at all
Had the same problem when the door switch broke. The electronics of the fridge thought the door was open and therefore the fridge would not cool. I noticed that the light wouldn't turn off when the door was closed to discover the switch was broken. It was an $11 part which my husband replaced and the fridge works fine now.
Mar 16, 2014 | Refrigerators
Freezer goes off with brief power failure + does not reset
What Samsung said is untrue....
The fridge and freezer have default settings...8 and 38 deg. If it looses power and is restored it will default to that....
This fridge is a complex device and is compute chip controlled.
There are tests that you can run if you have the ability to read and follow directions....That will allow you to guide a service person to what your problem is. They will probably not have this information so I am giving you the link to the service manual...
Good luck
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Jan 29, 2010 | Samsung RB215LASH
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Refrigerators Logo
121 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
