Question about Brother HL 2140 Laser Printer
The page prints with a regular black spot down the middle.
  • Brother Master
  • 1,915 Answers
Evenly spaced black dot down page could be either the transfer roller, fuser or drum unit. If you measure the distance you will know which, but most common is the drum unit. If you have another drum try it, your problem will likely go away. If not measure the distance from the start of one dot to the start of the next and post that meaurement.
Posted on Mar 31, 2011
  • h_u6 Mar 31, 2011
    Hi, i don't have another drum unit but the distance is 7.3cm. Thanks for the reply :)
4 Suggested Answers
Arius
  • 446 Answers
SOURCE: Canon LBP 1210 Laser Printer black mess down middle of page
the prob could be in the fusing unit, or the fuser rollers, chances are there is a sticky toner adhered onto its surface, (the red roller on the top is the pressure roller the bottom roller is the fuser roller.
this area could are so hot, so take precautionary measure when cleaning this rollers, this could be from other medium materials that recently usd and tends to stick on the surface of the roller.
kindly clean this one with dry cloth or cloth damped with oil, though its best to clean this while it is hot, but be careful
goodluck
Posted on Aug 01, 2008
callonafo
  • 174 Answers
SOURCE: A black line is printed down the middle of pafe
The problem may be from either from the toner cartridge or the settings of the printer. change the toner first and see whether he problem still persist and also make sure that the settings of the printer on your system is ok, if the problem still persist after doing all this then it implies that you need to service your printer.
Posted on Sep 25, 2009
xptareq2000
  • 1447 Answers
SOURCE: PRINTER NOT PRINTING ENTIRE PAGE
this spot is opc drum i mean cartridge unite
change it then solve your problem
Posted on Sep 07, 2009
Xerox 7435 printing spot on paper
Spots on the page in a regular pattern are usually due to a problem on that colour drum or on the IBT black transfer belt.
more investigation needed.
good luck..
Jun 04, 2015 | Xerox Office Equipment & Supplies
I have a black line printing down the middle of the page that smears when touched
U didnt write what model of machine you hawe,but probably,I thinh the fixing roller or film on your's machine heater is damaged
Oct 10, 2014 | Canon Office Equipment & Supplies
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
What can we do about dark toner spots that are appearing on the right side of documents we print? We have tried using a can of air spray to clean the inside of the printer, but to no avail.
I have a Brother HL 4040cn color laser printer and I had the same problem. On every page I printed there were these black dots that appeared down the right side of the page in regular intervals. I tried the automatic drum cleaner and that didn't work. I opened the printer from door, removed the black toner cartridge and looked at the drum. Sure enough there was a speck of black crusted toner stuck to the drum. I used a q-tip and lightly scrubbed at the spot to remove the toner then I used the gear on the left side of the drum to rotate it and check for any other smudges and there were none. Put the toner cartridge back in and it was good to go again...no black dots!!
Hope this helps someone because I couldn't find the solution myself when I searched.
Sep 22, 2010 | Brother Office Equipment & Supplies
Light swath of printing down middle of page..
This is due to Black developer , Kindly approach authorised service center to get it changed.
Best Regards
Mar 01, 2010 | Samsung CLX 3160fn All-In-One Printer
Brother9440 black dots appearing in line close to middle
it is problem drum spot open ypur printer drum unite and chack it or buy new one
Jul 23, 2009 | Brother MFC-9440CN Laser Printer
Black line down the middle of my copies
It sounds like you have a dead spot in your imager.
Feb 20, 2009 | Dell All-in-One 968+ Wireless Network Card...
The fuser film sleeve is more than likely torn. You can get just the sleeve and install it - or you can get the assembly. The p# is HM1-0237
Sep 10, 2008 | Canon imageCLASS D320 Laser Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Brother HL 2140 Laser Printer Logo
464 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
