How do i turn my wireless on, from my router?
  • 32,281 Answers
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Posted on Mar 31, 2011
Wifi is turned off. How do I turn it on?
Stuart,
Some NetGear routers have a wireless button to enable/disable the wireless feature. Look for a wireless LED on the front of the router, if it is off check the back of the router for a wireless button. Press the button for 5 seconds to turn the wireless feature on/off. If that doesn't work you may need to login to the router to enable the wireless feature. Here's a snipet from the NetGear knowledgebase:
1. Type http://192.168.0.1 or http://192.168.1.1 in an Internet browser - some routers use the first URL while others use the second. If one of these does not bring you to the router's login screen, see If You Cannot Log on to Your Router.
2. Enter the user name and password; the defaults are admin and password unless you have changed them. NETGEAR strongly recommends changing the default user name for your network security.
3. Check Wireless Settings > Advanced > Enable Wireless Router Radio. For newer routers with a Genie interface, click on the ADVANCED tab > Advanced Setup > Wireless Settings > Enable Wireless Router Radio.
Note: You will need to uncheck two separate Enable Wireless Router Radio box if your router is dual band. One for the 2.4GHz and one for the 5GHz network.
I hope this helps.
Mar 15, 2014 | NetGear N150 / RANGEMAX 150 Router
Hi, I'm trying to set up a TrueMobile 2300 broadband wireless router... It is turned on and both Power and Wireless lights are turned on. I can connect to it from my laptop but it doesn't connect to the...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 21, 2011 | Dell TrueMobile 2300 Wireless Router...
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
CAN I SET UP A ROUTER USING A PS3
No, the wireless card in the PS3 is just ike a wireless card in a computer. You cannot turn a wireless card into a wireless router, a wireless router is a special piece of equipment.
You need to purchase a wireless router.
Feb 01, 2010 | NetGear WGR614 Wireless Router
Wireless capability not turned on
Turn off all PC's that are attached to the router. Try unplugging the router for at least two minutes and plugging it back in, then try to turn the wireless back on.
Jan 02, 2010 | Actiontec (GT701WG) Wireless Router
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I can not access the internet when I install my linksys wireless router.
Is the DSL or Cable modem connected to the Wireless router?
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 19, 2009 | Linksys Wireless-G WRT54G Router
AFRAID OF SOMEONE IS LOOKING MY COMPUTER
Very, very highly unlikely. It doesn't work like that.
Netgear is probably the manufacturer of your wireless card, and the rubbish software they give you is freaking you out.
Nov 18, 2009 | Actiontec (GT704WG) Router
Turn off the wireless
Login to the Router and then disable the Wireless Radio from the Wireless Settings option to turn OFF the Wireless signal/network.
Oct 05, 2009 | Actiontec (GT704WG) Router
Router won't connect to wireless
Can you clarify the question.
Is there a modem (cable or verizon) connected to your router; if so you might need to turn off your modem, wireless router and computer for five minutes. Then turn on the modem, wait 5 minutes, turn on the wireless router wait 5 minutes, and then boot your computer. Also, make sure your computer's network card is set to DHCP, which automatically assigns your computer an ip address from the wireless router.
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
