Question about RCA D61W20 61" Rear Projection Television
Please tell me what to do with my rca 61"
Rca 61" will not stay on.blinks on and off. same problem alot of people are having.
  • bto323 Sep 08, 2008
    My 61 Inch RCA HDTV WIll Blink A Green Light 3 Times Then Stays Off, Won't Turn On! Please Help!!!
  • jeff666 Sep 25, 2008
    wont come on blinks 3 times and stays off
    Genius:
  • 2,920 Answers
Power supply is bad
Posted on Sep 03, 2008
RCA D61W20 61 in. Rear Projection Television blinks three times when trying to turn it on then quits blinking and the television will never come on. What's the problem?
Most likely its the CP150, CP120 and CP114 capacitors. You can get the repair kit with that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Jan 08, 2010 | RCA D61W20 61" Rear Projection Television
How to replace the bulbs for the RCA DD61W20 61 in. Rear Projection Television?
They have some kind of Black Tar on CTR boards holding them onto neck of Tubes, you will have to remove the Front and Back of TV in order to Change out the Tubes its alot of work removing 100 screws.I have no Idea Why RCA built them to be so hard to get to!
Jan 01, 2010 | RCA D61W20 61" Rear Projection Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Plug it in and the light flashes 5 time than stays on but dos not turn on
lamp needs replacing?? That's what the manual says for 5 x's blinking...www.discountmerchant.com is where I bought mine. But I am San Diego local, not sure how much w/ shippinh.
Mar 23, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
61 RCA Screen Problems
This is a bad sign of video board backlight going to failure.Make sure u get a warrenty repair,make sure they replace video backlight board.Or exchange the tv.U got a bad IC U could call the CPU for the board.It have intermitent ground sort.U can unplug the power,replug the power,it will work,but this temporally fix only.The high power of the board will kill the IC sooner or later.
Feb 26, 2009 | RCA HD61W66 61" Projection HDTV
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Mar 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA D61W20 61" Rear Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
