Question about ASUS P5GC-MX/1333 Motherboard
Not video display, only amber color when the cpu is on
    Problem Solver:
  • 10 Answers
Don't worry! The amber light is normal on most motherboards unless it is flashing. First, make sure that you have all of the basic components installed on your motherboard. Also be sure that the video cables in the back are connected correctly to your computer and monitor. You may want to try it on another monitor as well. If the problem persists the make sure you have a graphics card installed as well. If the problem still persists then re-seat the components on the motherboard and try again. Also, be sure that your power supply is installed to all of the parts correctly and that it has enough power for your machine.
Posted on Mar 31, 2011
My computer won't display anything on the screen, the power button is an amber color and the CPU fan is extremely loud. This is on a Dell Precision Workstation 670
Normally when the CPU fan gets very loud it is because of an accumulation of dust. It cant revolve fast enough to cool your CPU so it will want to close down.
You need to open up the computer and blow the dust off the fan blades, preferably with an air spray can. Report back when you have done this!
Dec 08, 2013 | Computers & Internet
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Monitor will not display desktop, however, it does display have multi-colored vertical lines throughout.
You have eliminated the CPU/Video card as a problem so you should try changing the video cable.
There is a good chance that the cable is bad if the multi-colored lines you are describing is the "test pattern". So swap out the cable and see if that fixes it. If that doesn't fix the problem and the monitor won't work with another CPU, it looks like you are going to need a new monitor.
Jan 17, 2011 | Acer X221WSD Monitor
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
My monitor will not come on, the on/off light flashes occasionally and the monitor gives over a very brief light
make sure that your cpu is working. if the cpu is dead, there will be no display in the monitor. If the monitor light is flashing as you said, it could be the CPU not sending video signal to the monitor. also check if the cpu beeps when you start your computer. if not, check your cpu. try to re-seat your RAM modules. this will solve most of these types of problems
Sep 03, 2009 | Computers & Internet
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
ASUS P5GC-MX/1333 Motherboard Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
