Question about Koolatron Koolscapes 84 Gallon Pond Kit
What size hole need to be dug to fit the liner?
  • 56 Answers
The Koolatron Koolscapes 84 Gallon Pond Kit contains a 6x6 foot liner. The actual dimensions of the pond could be varied but you will want a 6-10 inch overlap on the bank. Basically depth x2 + width = 5ft. 2-6in. So approximately 1ft deep by 3ft. across. If you are planning on keeping koi 2ft. deep is the bare minimum 3ft. if you have freezing conditions so I wouldn't recommend it with a pond of this size.
Posted on Mar 31, 2011
I have lost the screws to my 50" soniq tv base. What size screws do I need
Buy an inexpensive screw hole size template (used for inserting screws of unknown size into it, and reading what size hole it fits into, and then going to buy that screw) at Home Depot (HD) or Loews. If there is room to lay the template over one of the holes, you can eyeball which hole on the template is about the same diameter of the screw hole on the base. Then go to the store and look for that size screw (machine screw Vs wood screw), and purchase one of each of three sizes (the one that appears to be the one, and one that is the next size down, and one that is one size larger. Then see which one fits in the base (this will be a bit of trial an error). This should work until the right size is identified.
Sep 19, 2014 | Televison & Video
Heater Hose Replacement
Well, I am sure that you do not want to hear this, but to get to the heater core you must remove the passenger fender liner. Most mechanics would cut a hole in the fender liner and then weld it back up once the job was done just to make the job quicker. This is one of those "Better Ideas" that Ford is famous for.
May 19, 2013 | Cars & Trucks
I am trying to buy my son a Nitro snowboard for xmas and would like to know if I need to order a wide board. He is 5ft 11inchs and a size 10 1/2.
You should not need to order a wide. The length of his board is heavily dependent on his weight. If he were on anything less then a 157, you could be comcerned, but a number of their boards are available in a mid-wide.The size of board designed for his body weight and in general, his height, should get him into a wide enough boot to fit his feet.
Although, the tendency is definitely to go shorter then the camber of the board is designed and this can be appropriate/affected by terrain and riding style. Be a little weary of choosing to small of a board.
Another key would be the brand of boots he has or gets. Some brands use two size liners in the same outer shell. Burton is a good choice in boots with their one-to-one size shell and liners. Giving the rider the smallest outer shell possible in relation to their liner.
Nov 26, 2012 | Nitro Winter Sports
We have a problem with flooding in our garden we have fitted a length of drainage pipe and dug out a hole at the end to hold a submersible pump but the sides are washing away and clogging the pump how can...
Suppose you put the pump in a five gallon bucket with a hole cut in the side to accept the drainage pipe. Bury the bucket the appropriate depth.
Gary
Apr 26, 2011 | Garden
Does the chimney need a stainless steel liner
If the fuel is either wood (or any wood products) or oil it is required to have a stainless steel liner. Gas burning appliances need an Aluminum liner. Make sure it is sized correctly and not over sized.
Feb 17, 2011 | Heating & Cooling
Wire gets up to the nozzle and jams up then tangles in feed wheels in machine
Try removeing the tip before running wire threw liner. If this doesn't work, remove the defuser, run wire out . Replace the defuser, making sure the liner fits inside the defuser Replace tip. leave enough wire out so defuser & tip can be reassembled. Once you get to the tip you will find iff it is the proper size. If this does not fix the problem, remove the liner. Check to see if it has any kinks If so replace. When replacing the liner make sure not to cut to short. Put liner in gun, attach to machine.Make sure you have enough liner sticking out to make proper contact with the inside of your defuser Trim liner to fit. You should make contact with defuser just before defuser is fully tightened. This is where you eletrical power comes from. replace tip.
Jan 05, 2011 | Welding Tools
I have a 99 xj8 my 'cylinder liner' dissolved!
Yes, these engines use a special coating in the cylinder bores, and they are big problems. Although , if you check on the net, you will find its possible to get ordinary cylinder liners that can be fitted and bored to size.
Oct 19, 2009 | 2007 Jaguar XJ Vanden Plas Sedan
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
Basement flooding through sumphole
okay here 4 solutions but they both going to cost .....
1. the clay they dug out was to keep the water from entering the building and when they put in the gravel that only filtered the water.....
try one of these:
1. if your yard is big enough to redig you will have remove what they installed out and redig a new area that has clay and have it repacked near the house that was your sealant..
2. you will need a waterproof sealant or liner install on the side of house..
3. have a concrete slab poured against the house but sloped away from house......
4. go get a waterproof liner like they use for ponds and dig the yard down and away from house and lay the liner against the house about 2 feet of the liner and the rest sloping away from house then refill on top of liner but not sure how long that will last because it will deteorate but not too soon...
that clay that was removed was your sealant the gravel that is there now acts like a filter only to keep out debris but let the water to still slip through....
and drylock paint will hold for a min but the water needs to redirected away from the house
Nov 11, 2008 | Plumbing
Koolatron Koolscapes 84 Gallon Pond Kit Logo
179 people viewed this question
Top Koolatron Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Koolatron Garden Expert? Answer questions, earn points and help others
