Question about Maytag MSD2736GR Side by Side Refrigerator
The freezer and the refrigerator stop cooling. I'm looking for the electronic control board, but I don't know where is located??
  • Maytag Master
  • 43,501 Answers
The control board is located behind a panel on the back of the fridge...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 31, 2011
Power went out now back on. Samsung rs261mdwp has 1 blinking light on freezer side. What is this and how to fix?
Usually when there is a power failure or surge the PCB printed circuit board can be damaged on old or new refrigerators. It is just one of the problems associated with electronic controlled refrigerators. Your model has a=> DA41-00669A Control Board Unplug and examine to see if there are swollen capacitors or burn marks. You cannot always see damage to the board so if not then return the control board. I'm here if you care to ask questions. Compressor and fans stop? Cooling stops? Let me know by answering my post here, Thanks John T. Appliance 911
Contact
Apr 29, 2015 | Samsung Refrigerators
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Hello, I cleaned the refregerator ( not freezer) faster..so the door was open a several time but not for long time (didn't turn it off).After a few hours I noticed the refrigerator and the freezer...
Hi Tania,
This could be that the freezer is on a defrost cycle. Let it go overnight and see if you have temp in the morning. Let me know what happens so I can find out more if no relief.
Joe
Sep 07, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works great, but the refridgerator is not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Kenmore Refrigerators
The refrigerator isn't cooling. Freezer is ok.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 06, 2010 | Samsung RS265LABP Side by Side...
My refrigerator & freezer no longer cooling
I will need to help you first by telling you I can help. But is it possible that you could find a model number and brand name.I see everything is going to be lost so if you want me to help you repair let me know soon, I will show you the places to look for these numbers in one moment. Sea Breeze
Dec 10, 2009 | Refrigerators
Freezer has stuck in defront and stops cooling
Yours has a defrost timer board inside the fresh food compartment and behind the control panel. The only way to stop this is by replacing the board. Part number 4388932 and here is a view of its location inside the fresh food compartment. Just be sure the power is unplugged while working with board.
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
KSRG25FK Control Panel
Thanks, Sea Breeze
Aug 17, 2009 | Refrigerators
Control panel not working and fridge and freezer
You might have part of the answer in your own question - You would need to have it serviced - most likely the control board / electronic controls that has gone bad - this board controls compressor cycling and other functions of your refrigerator. Look for any error messages or blinking lights or a red service light if any - you could try unplugging your refrigerator for a few minutes and plug it in again if you are lucky and things reset otherwise have it checked. There is nothing much you can do on your own here without knowledge on the parts and how to locate it.
Other than control boards, if your compressor IS running but cooling takes a long time then check the condensers at the back if they are dirty, you need to keep those dust free and clean them about once or twice a year - warm, no cool, compressor running, I would then check for low refrigerant / leaks in the system (although rare). Most common problems affectin refrigerators are defrost timer problems, relays and controll boards going bad
Aug 17, 2009 | KitchenAid Refrigerators
2002 Kenmore 160.61 Refrig / freezer (top)
I assume that you noticed a loss of cooling in the refrigerator and freezer? In order to tell if it's the defrost timer, a good idea would be to check and see if there is a large amount of ice behind the interior back panel of the freezer (where the evap fan motor is located). If there is, you most likely have a defrost problem. There should be some frost, but it shouldn't be thick chunks of ice.
Otherwise, you probably just need to replace the fan. If you have a GE that takes an electronic control board, you may need to replace it as well. Please let me know if you have any more questions.
Mar 09, 2008 | Refrigerators
Maytag MSD2736GR Side by Side Refrigerator Logo
62 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
